35 inch tire not fitting on h3?
Old Mar 21, 2015 | 09:25 AM
destination66's Avatar
Default 35 inch tire not fitting on h3?
Hopefully somebody can help me. I have a 06 hummer h3 lifted 2'5 inches. I recently bought 20x8.5 10mm 775s and 35/12.50R20 nitto trail grapplers. I go to get them installed and I'm being told I need to have the truck lifted more and possibly need spacers? Is that normal for the combination. Everything I've researched on multiple sites say this would fit (with normal rubbing in lock) should I buy the pieces the shop says I need or head somewhere else?
Old Mar 21, 2015 | 02:10 PM
rsc's Avatar
rsc
I've had 35s on my H3, and my wife has swapped them onto her H3 too with no problems beyond the side biter tread rubbing at full lock. My 33s did the same, but at stock height on my wife's truck the 35's barely touched the sway bar until I raised the front to 23.25". This was on the stock rims though.
Old Mar 21, 2015 | 05:24 PM
Happy Hummer's Avatar
I'm assuming you made certain the offset and center opening were the correct size?
If memory serves me.....
https://www.hummerforums.com/forum/tire-wheel-32/wheel-offset-h3-18%22-wheel-11974/
Chris
Old Mar 22, 2015 | 12:18 AM
fharmon1's Avatar
I've got the same set up you just bought except for tires, I have 35" TOYO. I had discount tire tell me they wouldn't fit, went to another tire shop and they installed them with no issues. Ive had them on for about a year now with no issues.
Old Mar 22, 2015 | 05:17 PM
amrg's Avatar
I too have the same setup except in a 17" wheel/tire. Still got some minor rubbing at full lock (nothing serious at all)
Old Mar 22, 2015 | 09:37 PM
skeeter's Avatar
I had 18s and 35s, and I had mine installed at discount tire with no problems. I ran those for several years with no problems.
Old Mar 23, 2015 | 12:41 PM
The rubber will fit. Your trouble is caused by your rim selection.
Old Mar 23, 2015 | 08:05 PM
The tire will fit but the rims backspacing could be an issue.
Do you have the backspace specs?
Old Mar 24, 2015 | 07:42 AM
Problem was solved. Took it to a guy not far from there. Cranked it up a little more in the front and everything was fine
Thanks for the replys
Old Mar 24, 2015 | 01:45 PM
CurtisP87's Avatar
I hope you (or this someone) measured how much you lifted the front. If you go too far you'll start tearing up the front end.
