30k Maintenance?
Old Feb 24, 2008 | 08:16 PM
GarrettMoore's Avatar
Default 30k Maintenance?
I do not have an H3 owners manual, so can someone please tell me what it suggests for the 30k maintenance?
Thanks.
Old Feb 24, 2008 | 08:33 PM
Default RE: 30k Maintenance?
Change oil & filter, lubricate chassis, check for leaks/damage, rotate tires and check pressure, inspect brake system, check engine coolant, wiper fluid levels, inspect fuel system, inspect exhaust system and repair/replace worn/damaged parts as required.
Old Feb 24, 2008 | 08:41 PM
Ken06H3's Avatar
This may help you with the manual issue http://www.hummeranswers.com/
Old Feb 24, 2008 | 09:23 PM
HummerMike's Avatar
Call your Hummer dealer. 30K should be something like oil change, tire rotation, alignment, fuel system clean, etc..
Old Feb 25, 2008 | 09:12 AM
Thanks everyone.
Old Apr 26, 2008 | 10:02 PM
SandT_H3's Avatar
How much should the 30k service cost?
I went to my dealer today and they want 541 plus tax for the service. Here is the list of things they gave me.
Change oil and filter
Rotate & Balance tires
Multipoint inspection & lube chassis
Inspect Brake System
Replace wiper blades
Perform Battery Srevice
Perform cooling system flush
Replace PVC Valve
Inspect A/C System
Lube Body Components
Inspect Passenger Cabin Air Filter
Exterior wash and vacuum
Transmission Flush
Perform Engine Oil Service
Perform Fuel Conditioning Service
Now this is everything they tell me has to be done and then on top of it they recomend that I pay $12 for them to check the alignment and then if they feel it needs to be aligned then they will do that too for $80. Other sugested services but not mandatory are Rear diff service-$107 and front diff service-$57.
Has anybody had their 30k done yet and if so were the prices this high? I am thinking of trying other florida dealers as if I can save enough it may be worth driving to them for my service.
Stan
Old Apr 27, 2008 | 05:30 PM
GOFASTER's Avatar
ORIGINAL: SandT_H3
Replace PVC Valve
Inspect A/C System
Transmission Flush
Stan
$541?? F-That!!
Old Apr 27, 2008 | 10:51 PM
Only at 10K on the H3 so haven't got to that point yet with the Alpha.
Old Apr 28, 2008 | 01:12 AM
SamHouseIII's Avatar
I am thinking of having the wife take in our H3 for its 30K service while I am out of country.
Sam
Old Jul 1, 2008 | 12:30 PM
mountainbiker's Avatar
ORIGINAL: SandT_H3
Replace PVC Valve
Inspect A/C System
Transmission Flush
I wonder if this is a generic checklist, because I thought I read there is not a cabin air filter.
