2008 Transfer case
I am about to change the fluid in my transfer case and had a couple of questions.
Does the 2008 require additional fluid in the TC, to be added through the speed sensor hole? My owner manual says to use Dexron VI, but I thought I saw a TSB somewhere that says use manual transmission fluid- what should I use? |
new BIBLE,,,?
this topic would win IF it were based SOULy on the NUMBER of resurrections.
do sum searchin and you will find endless discussion on this topic on which i do not PONTIFICATE someone will remember where |
Originally Posted by CARdiac
(Post 261862)
(Post 261862)
I have seen manuals that state Dextron and others that state manual trans fluid. I talked to the service manager and the trans/T-case tech and he said he uses the manual trans fluid on T-case changes and rebuilds. So, it looks like it depends on the tech. I know that does not help a whole lot.;) |
Originally Posted by TAINTER
(Post 261874)
NOPE, that is only for the 06 and early 07 H3s with VIN#s under a specific #.
Best bet, to have your 5/100 warranty cover it is to contact your servicing dealer and ask them what they say.
(Post 261874)
Originally Posted by drtom
(Post 261872)
do sum searchin and you will find endless discussion on this topic on which i do not PONTIFICATE someone will remember where But thank you again :rolleyes: |
after serious consideration,,,
ive concluded this;
front wheel drive vehicles use atf(not the gun running feds) because everything in the drive train tranny,chain drive are in one soup. since there are clutches and bands,it requires atf and the gears and chain get stuck with it,,,,even though the 90 weight is a better juice for them. hence a smart tech knowing this uses the heavy bodied stuff in the tr case its all metal to metal gears in the transfer case just like a stick shift/diff, so why not?!! the gears in the tranny would love it but not the clutches/bands. more details,,,in the old days,limited slip diffs with clutches used the heavy stuff ,with a friction additive to make the clutches happy. so,,,what does a stick shift front drive car use????,,,its all metal to metal huh? |
Your best bet is to use what your owners manual calls for. If something happens GM can't claim you out in the wrong fluid type.
If your calling a dealer for advice you had better ask for the shop foreman, I have very seldom seen a service 'advisor' who knew one end of the car from the other. |
