2008 H3 5cyl Radiator Replacement
Old Oct 11, 2012 | 10:49 AM
Robrote's Avatar
Default 2008 H3 5cyl Radiator Replacement
Hello all. I need to replace the Rad in my 2008, H3 5cyl. I did some searching on here and never could find a decent post to explain the ins and outs of replacing this part. How difficult is it? Any hiddend issues I should look for? I have put lots of Rads in but never messed with a Hummer before.
Any advice would be appreciated.
Old Oct 11, 2012 | 11:11 AM
Welcome. If you have done radiator R&Rs before, the H3 is about as simple as it gets. Take a look.
If you have not done a radiator in a long time, it is still easy, but done a little different than the days of yesteryear.
No radiator drain, you remove the lower radiator hose to drain the coolant. A round hose clamp pliers and fan clutch wrench will make it a breeze.
Once the fan is off, you can slide the shroud up out of the truck by removing the radiator end of the upper hose, then you will see there are a top center and top each side mounts that need to be unbolted after the trans cooler lines (at the bottom) are disconnected to lift the radiator out.
Good luck.
Old Oct 11, 2012 | 12:06 PM
Robrote's Avatar
Most excellent. Thank you for the pics as well. I am assuming the Trans coolant lines are held in with the standard GM E-lock clips?
Old Oct 11, 2012 | 02:17 PM
egroegart's Avatar
What was wrong with your old radiator? I am asking because a lot of us are having cracks near the top of the radiator caused by the frame.
Old Oct 11, 2012 | 02:25 PM
Robrote's Avatar
Same deal ego. Leaking around the top. I bought a replacement online for 215.00 I figure if it's going to go every 4 years, I'm not spending 600 for a dealer item.
Old Mar 6, 2013 | 07:21 AM
Ernie R's Avatar
Do you need a special too. To remove the transmission cooler liner or just the 3/4 inch wrench?
Old Mar 6, 2013 | 07:23 AM
Ernie R's Avatar
Tool (typo)
sattv
Aug 8, 2012 06:30 PM
bankauto888
Apr 4, 2011 11:05 PM
Sugarphreak
Jun 27, 2010 06:44 PM
RyanCodyH3
Feb 17, 2008 11:06 PM
jdrew
Apr 13, 2007 02:15 PM
