2008 Alpha Making Loud front right clunk when turning sharp
Old Dec 6, 2018 | 08:43 AM
CMBAMF's Avatar
Originally Posted by tainter
plastic shift fork may be worn or broken inside keeping the rig in 4hi lock,
2008?
Old Dec 6, 2018 | 09:59 AM
Originally Posted by TAINTER
Plastic shift fork may be worn or broken inside keeping the rig in 4HI LOCK,
2008s do not have any plastic forks.
Old Dec 6, 2018 | 10:05 AM
Originally Posted by CMBAMF
Installed the new encoder motor with the vehicle in neutral and the tcase in neutral. No change at all. The encoder
motor and tcase still dont seem to line up? Could the TCCM be bad? It seems to rotate the encoder motor properly and the correct amount, they just don’t line up! Could something in the tcase be bent causing the shaft to be slightly off? Never been inside of one of these
The TCCM reads voltage from the T Case buttons, initiates position through the T Case actuator, recognizes position, and confirms position. So it is possible. Do you have a sunroof? Is so, has the passenger floor ever got wet?
Be aware there are 2 different types of TCCMs based upon which T Case you have (ie.. the standard or low range off road) so confirm that if you order one.
Old Dec 6, 2018 | 10:11 AM
But he said the previous owner rebuilt the transfer case. He could have use a plastic fork.
Also sorry Doc, but heck yes some of them do!
Had one in my 2008 H3 Alpha Offroad - Mr. Blue.
Plenty of people have reported plastic shift forks in 07, 08 and even some 09 H3/H3T with adventure/OffRoad pakages.
Old Dec 6, 2018 | 10:18 AM
That's news to me, there was an old GM bulletin that indicated a part change mid 2007. Now I suppose it is possible some T Cases manufactured before then, but not assembled into unit until after that date may have occurred, but I have never seen one. Maybe the place to check is through Borg Warner???
Old Dec 6, 2018 | 04:49 PM
DJB's Avatar
DJB
Just replaced the plastic fork in my '09. Transfer case was dated 06/06/2006. There were no indications that the transfer case had been replaced; the gasket between T case & transmission was as hard as a rock & had to be scraped off (in pieces), all of the wiring clips and fasteners were intact. My problem was a lack of 4WD lock.
Old Dec 7, 2018 | 12:01 PM
atvspeed4's Avatar
Two of our 2008s alphas have plastic shifter forks. So annoying to swap
Old Dec 7, 2018 | 12:09 PM
CMBAMF's Avatar
Looks like I’ll be pulling the tcase!
Old Dec 12, 2018 | 12:38 PM
slinnemeyer's Avatar
i have a 07 H3, how do I find out if fork is plastic vs metal?
Old Dec 12, 2018 | 02:21 PM
By opening the transfer case and looking inside or looking closely at the T case for a build date. I looked years ago if GM had any VIN# info
about that and I could not find anything.
It doesn't matter if everything works properly. I assume mine has one and it works just like it is supposed to, zero issues.
