2007 H3 Factory XM antenna
Old Jul 10, 2007 | 03:37 PM
a_mumford's Avatar
Default 2007 H3 Factory XM antenna
I want to add XM to my Base 2007 H3 - does anyone know if the 2007 H3 onstar aerial is dual/tri purpose ?? i.e. can I use the same unit for the XM antennae to avoid adding another ??
My dealer suggests "yes", but I want to save some cash and do the install myself.
Andrew Mumford
Old Jul 10, 2007 | 04:31 PM
Manford's Avatar
Default RE: 2007 H3 Factory XM antenna
I just went thru this situation last week....
If your H3 has the XM as an option, then the odds are good that the antenna will have the "tan lead" coming off of it. The Tan wire is the XM antenna, and if that is not there, you'll probably have to run a separate after-market antenna or splurge for the GM part. Search the threads, there is alot of information on the subject. The connectors are located directly behind the glove-box, clamped to a piece of the dash. Check there and you'll have a better idea of what actual unit is installed on the roof.
Good luck,
Manford
Old Jul 27, 2007 | 01:44 PM
ockie's Avatar
I would like to know this also. a_mumford, be sure to give us an update if you find out anything!
joewcob3
Jul 30, 2013 10:03 PM
skeeet
17
Mar 14, 2012 11:53 PM
Jgalvar
Jun 10, 2010 04:19 PM
lucky19942001
Oct 20, 2008 12:47 AM
wfturner
Aug 17, 2007 03:18 PM
