2007 H2 engine ticking
Old Jun 24, 2008 | 11:17 AM
redbullman's Avatar
Default 2007 H2 engine ticking
I own a 2007 H2 and the engine has started ticking. I think it is coming from the top end around the injectors or plugs. Anyone experiencing anything similar?
Old Jun 25, 2008 | 10:15 AM
ONALLFOURS's Avatar
Default RE: 2007 H2 engine ticking
Isn't it still under warranty? Even if you bought it used, the warranty is transferable. 5 yrs 50,000 miles bumper to bumper, and 100,000 drive train. Call Hummer GM at 866-486-6376
Old Jun 25, 2008 | 11:55 AM
redbullman's Avatar
Yea, it's still under warranty. It has 30k on it. The real bit*h is when you pay 80k for a Glacier Blue Special Edition and it needs warranty work, that doesn't make me feel good about GM quality.
Old Jun 25, 2008 | 01:01 PM
ONALLFOURS's Avatar
I see, you were just looking to vent some.
Moving on..........................
Old Jun 25, 2008 | 10:16 PM
Shlt happens no wonder WHAT AUTOMAKER!!!!
Old Jun 26, 2008 | 12:18 AM
hummech's Avatar
it sounds like a lifter which we have replaced a couple here and there. it is easy to diagnose with a tech 2 scanner. have the dealer do a power balance test which will tell them what cylinder it is on and they can replace the sticking lifter.
by the way i have been working on hummers for 15 years and work at a dealership that has a 98% fix it right and two world class techs. sometimes the mechanics are only as good as the support that the get from the vehicle manufactures. there is a lot of times we can not fix the vehicles as we feel that we need to. GM pay's the bills and we fix to their standards. i agree that not all techs are good and i would never hire any of them. the bottom line is i work for the customers.
Old Jun 26, 2008 | 04:59 AM
vkh2's Avatar
well, mine is an 03 .....when I first start it up engine runs good....after shut it off and then back on it also has that ticking noise butit goes away after some time ......got 46K Miles on the meter ....is that normal ?
Old Jun 26, 2008 | 08:01 AM
redbullman's Avatar
Yea, I'm venting but I found the problem. It's an exhaust leak coming from the left exhaust manifold. The rear bolt is missing and is creating a leak that goes away after it warms up. Wow, it's amazing what you can learn with a little diligence.
Old Jun 26, 2008 | 10:19 AM
ONALLFOURS's Avatar
Missing or broke off inside the block? Hope for missing. You may have to have the gasket replaced if it's been awhile. I fought headders on a 454 for 5 years with bolts coming out or snaping off inside the block. Each time I had to replace the gaskets or it still leaked.
nathanandthekid@hotmail.com
Jun 12, 2014 01:11 PM
man-of-war
Mar 25, 2014 09:56 PM
THE BEAST
16
Oct 23, 2009 03:30 AM
msl369
24
Oct 7, 2009 08:05 PM
finall
Mar 13, 2008 02:18 AM
