2006 H3 Red Oil Lamp coming on
Old Oct 29, 2014 | 02:38 PM
Toddzilla19's Avatar
Default 2006 H3 Red Oil Lamp coming on
All, I'm new to this board and was wondering if anyone has ever experienced their red oil lamp coming on intermittently? I changed the oil and filter (I used the Rotella oil that someone suggested) and that helped for about a week. Now it's coming on again. It's a 2006 with 109,000 miles. Had the transmission replaced at about 65,000 miles. Doesn't come on while driving. When I drive about 10 miles, then stop, the light comes on. Then goes off when I start driving again.
Thanks in advance!!
Old Oct 29, 2014 | 04:28 PM
norinco3264's Avatar
Sorry Todd, I have no clue what could be wrong. Just thought I'd mention that my oil lamp light has never come on once, but hopefully someone can help you out. GL
Old Oct 30, 2014 | 08:05 AM
Check the oil level, if it is low, you stop fast and inertia takes some of the sump oil to the front of the motor. 6 quarts, right?
Shall we assume you put in the proper grade?
Old Oct 30, 2014 | 10:12 AM
happythree's Avatar
when you stop , rpm is lowest,600. pressure is lowest. hit gas while stopped to 1000-2000 rpm. if light is out you have pressure problem if oil level is ok.
with a real gage you could see it drop huh.
my jeep gage drops to 35-40 in gear at idle, goes to 40 -55 running on the road.
a real gage would be tubing fed from the sending unit but i cannot find a fitting that fits the opening.
Old Oct 30, 2014 | 03:04 PM
Thanks in advance!!
Get that stuff out of there!!!... Rotella is for Diesel engines..
Use Mobil 1 synthetic (dexos approved) ..GL
JJJ
Oct 27, 2014 11:55 AM
drtom
Jan 17, 2011 09:23 PM
flacofuller
Dec 18, 2009 12:27 PM
hummer07
Nov 18, 2008 10:46 AM
JeepeaterH3
Sep 10, 2007 07:14 PM
