2006 H3- Key on and the only light is the check engine
Old Dec 1, 2015 | 06:13 PM
artjlynch's Avatar
Default 2006 H3- Key on and the only light is the check engine
I try to crank the H3 and nothing. The check engine light, mirror display, and airbag display are the only lights that come on.
I replaced the black plastic part of the ignition switch and no change.
Battery is fully charged, and clamps are clean and tight.
Any thoughts?
Old Dec 2, 2015 | 08:02 AM
bln1dotcom's Avatar
I just experienced a similar issue with my H3 two nights ago.
Did this happen to you during the day or night...? Wondering as mine happened at night. The first time I tried to crank with no result all the dash lights were off, 5 minutes later tried again with no crank and all dash lights lights came on and on the third try after another 5 minutes, it started.
I've researched multiple different H3 forums and some people have had a similar issue, however, I never saw one with a resolution. Have you heard anything?
Old Dec 2, 2015 | 08:08 AM
Any thoughts?
Are you referring to the OEM Battery Terminal Connectors? They might be clean, but the will NEVER be tight.... they SUCK!
There is probably 4 bazillion threads on the absolute need to hack off the POS OEM battery Terminal Connectors and replace them with a quality aftermarket set like Stingers or your own favorite brand. Do a search. First thing every H3, Colorado/Canyon (and more GM trucks) owners should do, get rid of them.
Easy thing to do to rule out the most common cause of electrical issues.
Old Dec 3, 2015 | 04:09 PM
artjlynch's Avatar
I changed the battery cables, still have the same problem. Hook the battery up head lights stay on and cannot be turned off. Power seats work, Could it be the BCM ?
Old Dec 4, 2015 | 01:44 PM
Do you have a sunroof? Has your front passenger side floor ever been wet? If so, yes it could be the BCM got wet (they absolutely do not tolerate water) which is located up behind the glove box and side kick plate area.
Old Dec 5, 2015 | 05:18 PM
artjlynch's Avatar
Replaced BCM, everything back to normal, but wont start. Tried the procedure to relearn the passlock, but no go. Guess I'll have to get it to the shop.
Old Dec 5, 2015 | 05:22 PM
skeeter's Avatar
when you replace the BCM it has to be reprogrammed through the truck or it will not work
Old Dec 15, 2015 | 11:47 AM
Jbarb78's Avatar
If the Passlock light is also illuminated, it's a known communication issue between the BCM and the ignition switch. The ignition switch is basically telling the BCM that the vehicle is being stolen and shuts off the fuel pump. Relearning Passlock trick is temporary, read it only lasts 100 cycles. I had the same issue for months, only code when plugged into a computer was for a thermostat issue, but when the service tech looked it up in GM's database with the no-crank symptom, the ignition switch issue was referenced and recommended replacement. $430 repair, but after 6 months of dealing with waiting 10 minutes to start after a lockout, it was worth it, problem solved.
Old Dec 15, 2015 | 09:04 PM
happythree's Avatar
anybody give any thought to adding some plastic above/around the bcm to keep it dry?
i think ill look at it.
Old Dec 16, 2015 | 04:16 AM
Broken Halo's Avatar
That would be like walking around Detroit at night wearing a bullet proof vest instead of just not walking around Detroit at night.
