2005 H2 engine hours and running boards
Old Feb 5, 2019 | 09:32 PM
Warriorking60's Avatar
Default 2005 H2 engine hours and running boards
Two questions,
1 The plastics pieces on the running boards are lifting up on the ends. Are there replacement pieces for this or can they be fastened down. Epoxy maybe ?
2 The engine hours display in the DIC. What is the use and can it be reset?
Old Feb 6, 2019 | 08:45 AM
1 - One my old GMC truck I ended up putting a self drilling screw (OEM look with the low flat black head) in each towards the ends when they started coming up. I know there are replacement step pads for some but I'm not sure there are any specific for ours.
2 - So that one can determine the amount of wear on the engine. Not terribly common on consumer vehicles but an engine hour meter is very common on commercial vehicles and engines in industrial things like forklifts, boats, etc. Because some vehicles might be run a LOT without actually moving (police cars, ambulances, cabs, etc) it is another way to determine when oil changes might be needed. No, by design, that is just like an odometer and cannot be reset.
Old Feb 6, 2019 | 01:26 PM
oceanbrave's Avatar
Complete Nerf Bars sets are available on ebay and amazon, but I've not seen the replacement plastic bits sold seperately.
I'd be tempted to carefully remove, clean and degrease the pads and stainless them clamp and re-glue OR neatly drill and fit screws (see JPG)
The tubes walls maybe quite hard and thick, it might be better to use regular screws rather than self-tapping screws as they might disintergrate (unless you have tool).
There are various types of nerf bar fitted, some come glued, some screwed, as with mine which are now stainless screws rather than stock mild steel.
I recently got all the mild steel parts shot-blasted and powder coated, the stainless tubes had special nut-inserts (Nutserts) which were rusted an siezed solid, these I drilled out and fitted new ones, also replaced all the stock black mild steel fixings ( bolts and washers etc) with A4 Stainless which will never rust!
Everything came up like new as you can see!
Old Feb 6, 2019 | 02:40 PM
That screw you circled is exactly where I put a screw in the ones on my GMC.
Old Feb 6, 2019 | 06:55 PM
Sirina2's Avatar
Default H2 hours
My 2005 H2 has 112732 miles 913 hours.
Old Feb 6, 2019 | 09:01 PM
Thank you all
Old Feb 7, 2019 | 11:11 AM
2003hummerH2's Avatar
My 2003 h2 has 53000 miles 3000 hours
Old Feb 13, 2019 | 12:35 AM
KTM640Dakar's Avatar
The hour meter flips to zero after 9999 hours.
Old Feb 16, 2019 | 12:58 AM
hmer's Avatar
208000k miles and almost 6k hours here .
clsimmon
May 15, 2017 09:34 PM
Zip Tie Man5
Jul 1, 2011 06:18 PM
TOYBOX
Mar 12, 2010 04:34 PM
jasonmb
Sep 24, 2009 01:40 PM
solarflare
Feb 21, 2008 05:49 PM
