2003 H2 battery discharging problems
Old Sep 23, 2007 | 10:23 PM
HammerDown's Avatar
Default RE: 2003 H2 battery dsicharging problems
It looks like it was the onstar fuse. I have it pulled and battery is not discharging.
Old Sep 24, 2007 | 12:24 PM
HammerDown's Avatar
Well I spoke too soon. The battery was dead this morning. I dropped the truck off at the local GM dealership and am leaving it there until they find something.
Old Sep 24, 2007 | 03:28 PM
Muddydawg75's Avatar
Good luck.... make sure you let us know what they found....please...
Old Sep 29, 2007 | 09:11 AM
MRDM1's Avatar
i had the same problem but i replace the battery at autozone $120 BUCKS NOW EVERYTHING WORKS
Old Oct 4, 2007 | 08:40 PM
saywhat's Avatar
I had this issue on my 2004 and the dealer installed a new battery and i never had another issue!
Old Oct 5, 2007 | 02:13 AM
ORIGINAL: saywhat
ME TOO!!!!!
Old Oct 7, 2007 | 02:21 AM
finall's Avatar
Same problem. Dead one morning on a year old battery. Charged battery. Took it in to GM. Battery tested OK. Has not done it since. No explanation.
The H2 hasa battery drawdown protection, so none of the above suggestions would matter anyway. The battery disconnects passive draws at 11V, so that you can still start the vehicle, as far as I know.
I wish some GM techs would cruise this site and confirm this kind of technical stuff, to tell us if what we are being told is true. And tell us that you are a GM tech, so we know the answer is not just a guess...
Old Feb 15, 2008 | 01:12 PM
mimoso's Avatar
I had the same problem wit mine and was told it was the seat control module havent had a problem since though
Old Feb 15, 2008 | 03:58 PM
SafariHummerH2's Avatar
Hello Friends, I've experienced the same problem but the truck sat without use for about 2 weeks. So I guess the battery just trickle drained from the computer.
I purchased from Ebay and installed a DELTRAN 12 VOLT BATTERY TENDER PLUS and a SIDE POST BATTERY DISCONNECT SWITCH for when my vehicle is not in use for long periods.
Old Feb 16, 2008 | 08:07 AM
calif phil's Avatar
I fought the same problem on my truck after I bought it. I went through a few batteries and had the dealer check it and they couldn't find anything wrong. I finally realized it was the ignition switch. Sometimes it would not shut off all the way and the little red battery light would be on.
