18x9 wheel question??
Old Oct 24, 2012 | 08:59 PM
Otto7668's Avatar
Default 18x9 wheel question??
I'm looking at getting some rims but don't want them to stick out far this is the info I have on them...
18X9 6-139.7 BOLT PATTERN
OFFSET---+10
HUB BORE---106.2
Anyone have any idea on how these will look?
Old Oct 25, 2012 | 04:27 PM
Otto7668's Avatar
Nobody?
Old Oct 25, 2012 | 10:40 PM
mgoblue85's Avatar
The offset determines how far they stick out.....tire width is also critical for clearance when turning....
Old Oct 26, 2012 | 03:25 PM
Otto7668's Avatar
Well I want to run 35x12.5r18 tires with a +10 offset..... Approx how far will they stick out?
Old Oct 27, 2012 | 04:24 PM
Otto7668's Avatar
And will the hub bore of these wheels work with the h3 need to know ASAP....trying to buy tonight
Old Oct 27, 2012 | 05:30 PM
Bunger's Avatar
Hub bore on an H3 is 101 mm. Hub is 100 mm.
H3's are hub centric, meaning the center bore aligns the wheel versus stud centric in which the lug nuts align the wheel.
You need to match the hub bore.
Old Oct 27, 2012 | 06:13 PM
skeeter's Avatar
just because it is designed hub centric does not mean you have to run hub centric wheels.
Old Oct 27, 2012 | 09:09 PM
Otto7668's Avatar
So if the wheels are 106mm they will work correct?
Old Oct 28, 2012 | 01:58 PM
Bunger's Avatar
No Skeet, you don't.
You just need to have a center bore larger than 100 mm and use the right kind of lug nuts.
I wouldn't do it on my truck though. Don't want to risk snapping lugs on the trails.
Old Oct 28, 2012 | 07:51 PM
skeeter's Avatar
You are correct sir. i can't remember if my wheels are hub centric or not. Most places give you new lug nuts or the oppurtunity to purchase the correct lug nuts
kav315
Feb 24, 2014 01:56 AM
RedHummerH3
Jun 21, 2012 06:45 PM
spencers21
Nov 26, 2010 03:41 PM
Vetteguy
Apr 25, 2010 09:04 PM
