186DEG T STAT
Old Sep 10, 2007 | 01:15 PM
CAMARO's Avatar
Default 186DEG T STAT
HELLO, HAS ANY ONE TRYED A 186DEG T STAT? PROS AND CONS...THANKS ANDY
Old Sep 11, 2007 | 06:46 PM
tomp's Avatar
Default RE: 186DEG T STAT
Yep, done that. Didn't change the temp guage a single mark. Waste of $$$
Called Jet Performance and they said that is normal for temp guage not to reflect a change - but I am not sure if aI buy into that.
Old Sep 11, 2007 | 10:24 PM
I have NO IDEA what you're talking about!!![8D]
Old Sep 11, 2007 | 10:46 PM
shortbus's Avatar
it's a thermostat, designed to inflict financial waste on the masses.
Old Sep 12, 2007 | 02:06 AM
Thanks shorty, I guess I'm GLAD that I have no idea, or I probably would've BOUGHT ONE!!![8D]
Old Sep 12, 2007 | 09:41 AM
CAMARO's Avatar
THE ONE I ORDERD WILL BE HEAR TO DAY.. WILL SEE WHAT HAPPENS.. STOCK IS 197DEG.
Old Sep 12, 2007 | 01:11 PM
blackstangs281's Avatar
If you are going to change your stat, you should get the computer programed for it.
Old Sep 13, 2007 | 11:09 AM
popocamaro1's Avatar
On my SS with H/C I swapped the factory 180 for the JET 160 and it dropped about 10 degrees. I never went over 200 even driving it in the georgia summer heat at the track , I did reprogram the computer as well however.
Old Sep 13, 2007 | 01:12 PM
CAMARO's Avatar
JUST FOUND OUT STOCK IS 187DEG.. O WELL.... MINE HAS NEVER GOT TO 200DEG YET.. SO I WILL LEAVE IT ALONE... THANKS, ANDY
Old Sep 13, 2007 | 02:55 PM
HumminNBoatin's Avatar
I had a Dodge durango and the Stock one was 180 degrees.I went and bought a 160 Degree Tstat and it did not drop the temp. I thought it would be great for the summer when I am towning the boat and sitting idle at theboat ramp after long hard hauls. In fact it was a pain in the a$$. The computer is dumps more gas into the enginee do get the temp to its stock operating temp. Therefore the getting a colder TStat is not only an initail waste of money but its costs you more to role down the road. I went from getting 11.5mpg in my Durango to 9mpg when I did this. If the computer can be changed to match it great. But I have learned my lesson on this with Computerized engines.
