07 h3 pcm problem
Old Oct 26, 2017 | 02:17 PM
Snow79man's Avatar
Default 07 h3 pcm problem
My 07 hummer ran and drove great, I pulled both pcm1 and pcm-b fuses out and left them out for 15 minutes, after putting them back in , my hummer will not start, it cranks but will not fire. Any help?
Old Oct 27, 2017 | 10:27 AM
Welcome to HF.
I moved this to the H3 section, which is where questions about H3s go. Crazy like that.
It would appear that you created the problem, so review what you did again very carefully. Have you made sure the fuses are good, in the correct location and properly in place?? You pulled #21 and #25, the spot for #26 is an empty (spare) .... could you have moved it over one spot by accident?
The fuse block diagram in the lid is upside down, but you probably knew that.
What would be the reason to pull those fuses to begin with?
Old Oct 27, 2017 | 07:15 PM
BruceS's Avatar
Probably need to do security relearn(pass-lock).
BiGDoG1010
Oct 27, 2013 06:48 PM
spusoccer
Dec 18, 2007 09:42 AM
Amanda
44
Sep 25, 2006 01:09 PM
HummerGuy
Sep 21, 2006 12:20 PM
