07 H3 low tire sensor
Old Sep 8, 2014 | 09:08 PM
wildhartleys's Avatar
Exclamation 07 H3 low tire sensor
The low tire alert came on today. As I went to check tire pressure each tire showed 25psi. I read the door jam sticker it says 30psi should be in them but on the tire it states 44psi. Confused, how much air should be in them?
Old Sep 9, 2014 | 07:22 AM
RKSmith163's Avatar
Your TPMS system is calibrated to the door jam pressure.
Old Sep 9, 2014 | 08:04 AM
Bunger's Avatar
25 psi is way too low for on-road driving.
I air down to 20 psi when offroading in rocks and normally run 38-40 psi for on-road driving.
38 psi may feel a little stiffer to you but your MPG will improve.
Old Sep 9, 2014 | 04:51 PM
I changed psi from 35 to 40. Better fuel economy and the same ride (not stiff at all) with my monroe monotubes on all 4 corners.
BTW, the pressure on the tire is MAXIMUM air pressure for the P-metric tires.. Get the LT tires and you can air up to 80psi.
C31322
Sep 11, 2013 03:27 PM
Kinder82
Apr 4, 2013 08:30 PM
Kimmea
Aug 1, 2012 07:47 PM
psych0
Sep 16, 2010 05:35 AM
mrhaney
Apr 16, 2006 10:46 PM
