07 H3 Base or 08 Adventure package?
Old Aug 17, 2012 | 03:03 PM
V8-H3's Avatar
Uh, no. None of the 07s have or had an 06 head.
The 07-10 I5s all use the same 3.7L LLR heads.
Yes the early model 07 also had the head trouble. Mine went at around 60,000. As the dealer told my, quite commen on the early model year ones.
Old Aug 18, 2012 | 02:21 PM
rsc's Avatar
rsc
Yeah, I thought the very first couple of 07's had the problem as well (probably an issue with floor stock parts remaining from the previous years production). I won't rule out an 07 for that, very slim chances of it being affected.
"Replied on December 01, 2009
Is your check engine light on also? There is an issue with the cylinder head on the inline 5 cylinder where it misfires at idle, and goes away above idle. Most often, I have seen #5 the one with the most misfires. The machining on the cylinder head was the issue, and is solved by head replacement. You don't have mileage listed, so I don't know if it is under warranty still, or not. This was most common on 2006, but I have done two on 07's in the past three weeks. This is not the only possibility, just highly probable, with your symptom. It can be confirmed with a cylinder leakdown test. If it is out of warranty, there are special tools and procedures required to do the job, and not have to remove the front cover to reset the timing chain"
ninjarider
26
Dec 9, 2014 04:43 PM
justanotherhemi
Mar 15, 2014 08:35 PM
mjh
Aug 23, 2007 09:46 AM
melvynray
17
Nov 5, 2006 12:55 AM
markthetech
Sep 7, 2006 05:50 PM
