03 H2 Oil Pressure Question
Old Aug 2, 2010 | 09:32 AM
txflatfisher's Avatar
Default 03 H2 Oil Pressure Question
03 H2 95k miles, no previous oil pressure symptoms. Drove from Houston to Dallas stopped to eat and shop, downtime 6hrs, got back in to startup no oil pressure on gauge, DIC chime going off, shut off engine to ck fluid level and such, no issues, started back up let warm up with no apparent knocking or temp issue, revved engine a couple times and gauge started working fine ,drove to hotel no issues (20miles). Next morning same issue no oil pressure, rev engine gauge work drove back to Houston 200 plus miles, now everytime we stop have to rev engine to get gauge to work.
Gauge cluster replaced about a year ago with new gauges.
Is this problem the gauge, sensor or pump.
Old Aug 2, 2010 | 01:20 PM
olfart's Avatar
if it triggered the DIC then it probaly isn't a gauge problem. If you drove home 200 miles with no engine probs and no over heating it appears that the oil pump and cirdulation is OK. So I would suspect a bad sensor.
________
Baha'i faith forum
Old Aug 2, 2010 | 01:22 PM
calif phil's Avatar
It could be any of those three items, you need someone to screw in a real pressure gauge and verify the oil pressure, You could also take a gamble and try a new oil pressure sending unit first.
myrddin
Dec 16, 2012 11:54 PM
drtom
Jan 17, 2011 09:23 PM
hummer07
Nov 18, 2008 10:46 AM
doan866
Oct 31, 2008 10:38 AM
jbnjc123
Feb 1, 2007 03:33 PM
