Turbonetics Sale & NOW 3yr/36k Powertrain Warranty
#32
RE: *NEW* Turbonetics H3 Turbo Kit - 350HP!
According to this it comes with an up-grade program with up loader
Turbonetics Hummer H3 Turbo Kits Include:
- Turbonetics 60-1 Stage V Turbocharger
- Turbonetics Evolution Wastegate
- Turbonetics Raptor Blow Off Valve
- Spearco Front Mount Intercooler
- (5) High Flow Injectors
- HP Tuners Tuned Software & Uploader
- SS304 Mandrel Bent Polished Exhaust Piping
- Aluminum Black Chrome Charge Piping
- AEM Dryflow Airfilter
- All V-Band Clamps & T-Bolt Clamps
- All Necessary Installation Hardware
- (1) Case Turbonetics TS-1 Synthetic Oil
Stock Power: 225 HP
Turbo Kit Power: 350 HP
Boost Level: 8 PSI
Stock Power: 225 HP
Boost Level: 8 PSI
#33
One of the benefits of a Turbo over a SuperCharger is that a turbo can be driven out of boost and it does not create a parasitic drag on the engine. Therefore, out of boost, the H3s should get MPG the same as stock. Under certain cicumstances you will see better gas mileage as you now have the power to tow, go up steep hills, etc without having to really push the engine into the higher RPMs.
Thanks, you are correct!
The nice thing about buying a Turbonetics turbo kit is that they only sell 100% complete kits. All turbo components, all installation components and full fuel management that is Plug n Play!
See Below
Thanks Dennis!
Have a Merry Christmas, Happy Holidays and Safe New Year Everyone!
Jesse
ORIGINAL: RutDogg
What is the fuel mileage with the turbo attached under normal driving conditions?
ORIGINAL: CerberusSVT
don't quote me, but the turbo shouldn't affect gas milage much if any under normal driving conditions (if you're not going into boost, it won't take any extra fuel to keep the same air/fuel ratio the same, in theory..)
ORIGINAL: RutDogg
ORIGINAL: patshemi
any dyno results? Also interested in PCM changes ? Will it help to have the pcm reprogramed ?PCM for less?
ORIGINAL: chewbarka
Do you have to re-tune the H-3's computer?
Thanks Dennis!
ORIGINAL: Dennis
Stock Power: 225 HP
Boost Level: 8 PSI
Stock Power: 225 HP
Boost Level: 8 PSI
Jesse
#34
ORIGINAL: TurboKits.com
Also, Spearco tests all of their intercoolers underwater for leaks, so a properly installed intercooler with properly torque'd t-bolt clamps can be completely submerged and run without leaks. If anything the water will help cool the charge and make a few extra HP
Yeah Jesse.. There's one heckler in every group.. And today it's me..
Seems like it's good kit and deal for those that need it..
#35
Merry Christmas! (Yeah I said it)
Jesse
Jesse
ORIGINAL: Crash
Ummm.. Yeah.. I need 350hp of water fording ability... Heck with that kind power it's not called fording.. It's called skipping... Of course the intercooler isn't in the water at the point.. Soo...
#37
Wholly crap, I have to visit this place more often. I made a comment on one of my forums that I could use more horses under the hood and BAM - HERE IT IS!! Now this is definitely something I would want in my H3.
#38
Iam 99% sure that a dealer can't void a warranty based on any aftermarket part. They do however, have the right to charge you to fix problems that they prove are caused by the part.
If you add a turbo and your tranny breaks, they can probably prove it was the turbo's fault. However, if your stereo stops working, they would have a hard time linking the 2...
Hope this made sense...
Heck yeah! Get in quick, we have only four of these kit slated for TurboKits.com customers... SO if you are interested a $500 deposit will hold one under your name!
Jesse
ORIGINAL: ZOO
What will adding this do to the Factory Warranty? I have heard GM would need to do testing to approve keeping the factory warranty.
Also what type of Octane gas will be needed?
ORIGINAL: inked
Jesse
