Newbie
Old Aug 22, 2010 | 09:27 PM
Lurch's Avatar
Default Newbie
Hello, new to the forum, I have a 06 h3 base model, not many mods done to it, I wired in a switch and relay to the abs actuator that turns off the abs and traction control. I got stuck twice in the mud from traction control taking over and decided there wouldn't be a third. Recently put a set of used 35's on steel wheels on it as my stock tires were near bald, had only slight rubbing on the mudguards so I bumped up the front torsion bars one inch and now only get a slight contact with the mudguards at full lock in turns. Had the normal problems of the transfer case melting inside causing mento be locked in four wheel, head dropped a valve seat and the hood ornament blowing off which I replaced before the recall came out. Upper ball joint is horribly loose made worse by the new 35's. Added a home brew backup camera mounted in the spare tire center cap... Working on designing a behind the bumper winch mount and roof rack with light bar and backup lights...
Old Sep 5, 2010 | 01:36 AM
ymail99f2's Avatar
, have attended networking events , accumulated a mountain of business cards, Now, ,Lesean Mccoy jersey, need to design , faithfully implement a system to stay in touch with the people , met , enhance those relationships, even after they become ,r clients, Without this, ,r networking ef,ts will have been in vain, Create a Step-by-Step Plan Step One: Prioritize You MUST prioritize! You don’t have limitless time, , , need to use it as efficiently as possible, Keep ,r networking strategy clearly in mind, Determine which relationships can develop into win-wins , both of ,, Gathering cards but keeping only the ones that , think will bring , business is a great mistake, Assign egories , ,r contacts depending on their importance to ,r business, In ,r contact-management softw,TROY AIKMAN jersey,, create a field named “Priority,” where , can enter their assigned egory,Giants jersey, This will help , set the timing as to how often , will get in touch with them, egory A: “Immediate” -- People with whom , definitely want to establish a relationship, In this egory , those whom , can help, with whom , can do business or who could become ,r client, , may want to get in touch with these people immediately , set up a time to meet with them again soon Category B: “Occasional” -- Those , will keep in touch with occasionally, perhaps once a quarter, just to say,Donte Whitner Jersey, “Hello! I’ve been thinking of ,,” This is not necessarily a sales call or letter, but simply to remind them of who , , , what , do, Category C: “Peripheral” -- Those ,’d like to keep in the database , review from time to time, but probably won’t contact them regularly, Step Two: Organize In addition to the usual contact in,mation, other important fields that , may want to set up in ,r database-management system could include: Industry or Profession -- Using this , can pull up all ,r realtor contacts , perhaps send them a helpful article , found that relates to real estate, Website -- You may want to look up more in,mation on their business, Notes -- Always keep good notes , track dates , other in,mation about ,Harry Carson jersey,r communiion with contacts, Then, if , hear from or meet someone six months later, ,Fred Taylor jersey,’ll know where , met him or her, It’s also important to make note of any special interests, needs or skills they may have, Always: Be consistent in the way , organize ,r contacts, Keep ,r in,mation up to date, ,r database is only of value if it’s kept current, Set up a schedule , ,rself to keep in touch with each of ,r contacts, Set ,r CRM softw, to remind , to make ,r calls , track ,r progress, Step Three: Work Your Plan When , return from a networking event, ,r first task should be to prioritize , enter the new contact in,mation ,’ve gathered, One way to do this easily is to scan all those cards into ,r database using a card scanner, It typically takes 15 minutes to scan 15 to 20 cards , tweak them, Cards with a lot of graphics or unusual fonts may need ,r help to correct the in,mation, Then send a brief email to everyone letting each one know how much , enjoyed meeting him or her, This can all be automated in ,r CRM, How Frequently Should You Keep in Touch, Every 30 days is typical, People don’t usually want to hear from , more frequently, A call or email once a month keeps , in their minds, Be Creative in Your Communiions, Consider their needs , what might be of interest or helpful to them, If , recently read a really good article on “widgets,” pull up all the contacts in ,r “widget makers” egory , send the article to them with a note, Perhaps send a Thought , the on how to get a better client, Make a list of ,r ideas ,Jabari Greer jersey, use them regularly, This lets them know ,’re thinking of them, Support each other’s businesses -- Discover ways to do this, Give referrals -- When , pass their card along to someone else, let him or her know that , did so , contact them again a few weeks later to follow up , find out if the referral worked out, Send a card to say “thank ,” or to congratulate them on a success, Purchase high-quality cards that communie both professionalism , caring, Invite them to attend a new networking event , just learned about, , email them with the relevant in,mation, Send them ,r newsletter,cheap New England Patriots jerseys, Remember: always be brief,Lofa Tatupu jersey, Respect the other person’s time, People , busy, so keep ,r communiions short, Faithful Follow Up is Essential Extraverts , “promoters,” who thoroughly enjoy meeting new people , , excellent networkers typically tend to avoid the more tedious task of following through on their intentions, They need to make extra ef,t in this ,a, Follow up is an ongoing process, Build ,r database, keep it up to ate ,Chris Williams jersey, keep in touch regularly to maintain an aw,ness of ,rself , ,r business, , never know who ,r contacts may meet who could benefit from ,r services or products, Networking is undoubtedly the easiest , most cost-effective way to grow almost any small business, After , gain a new customer, follow up becomes even more important, Keep in touch with , market to existing clients , customers, This will cost much less than acquiring new ones, Related:cheap authentic nfl jerseyscheap nfl jerseys
Old Sep 5, 2010 | 06:41 AM
OneNote's Avatar
OnenoteReview is about note taking software – Microsoft’s way of organizing that information. I’m a guy who has lots of stuff that I need to remember. I’ve spent a lot of time looking at different ways to organize that information on the computer...check this out.
farmtruc
Mar 23, 2015 11:44 AM
AMERICAN INFADEL
Jul 3, 2012 10:14 AM
Blown H2
May 12, 2012 06:33 AM
jockeyshift
Sep 17, 2008 04:54 AM
MJ50
Mar 28, 2006 01:40 PM
