Hummer H2 Wheel Center piece removal
Old Today | 12:06 PM
Mansour Ansari's Avatar
Default Hummer H2 Wheel Center piece removal
2003 H2 Hidden Lug Nut Mystery Solved – For Anyone Fighting Stuck Center Caps
Thought I'd share this in case it helps another H2 owner. I recently took my 2003 Hummer H2 (original wheels, Sport Package) to have a new set of BFGoodrich tires installed. The problem? Nobody could figure out how to expose the lug nuts.
Even the tire shop was scratching their heads. The lug nuts on my H2 are hidden behind the large chrome center wheel cap. I remembered removing them years ago, but after all this time they appeared completely seized.
Here's what finally worked:
  1. Spray WD-40 around the entire circumference of the center cap.
  2. Let it soak.
  3. Rotate the center cap counterclockwise until it stops.
  4. Use plastic trim tools and gentle pressure around the perimeter.
  5. Wiggle, pull, and be patient. Don't do this in the sunny day in Oklahoma. Find a shade. This will take time - elbow grease, some uncomfortable moments and fear of breaking the freaking things... they are very very expensive and hard to find.
  6. Repeat as needed. and hope!
In my case, years of dirt, oxidation, and grime had effectively glued the caps in place. Once the WD-40 penetrated the seam, the caps began rotating again.
The rear caps were the hardest. They would not rotate freely by hand, and I had to carefully apply pressure at different points while working them loose. I was honestly more worried about breaking the expensive original center caps than anything else.
Eventually,
all four popped free and exposed the lug nuts.
A few observations:
  • The caps are twist-lock, not screw-on.
  • Rotate fully counterclockwise before attempting removal.
  • Be careful with metal tools.
  • Original H2 center caps are getting harder and more expensive to replace.
  • Patience works better than force.
After removing one cap and inspecting the backside, I found no hidden screws or security mechanism—just locking tabs around the perimeter.
Hopefully this saves another H2 owner from a frustrating afternoon. And yes... after all the sweating, frustration, WD-40, and gentle persuasion, the reward is seeing a fresh set of BFGoodrich tires going onto a yellow H2 that still turns heads after more than twenty years. - Good luck to the next owner who finds himself staring at an H2 wheel wondering: "Where the heck are the lug nuts?"
nijoma
Mar 24, 2014 10:32 AM
whododat
19
Apr 25, 2013 12:07 PM
vanguard
Aug 3, 2012 01:38 PM
Lex_Ordo
18
Jul 13, 2007 05:48 PM
Ghostrider
Nov 7, 2006 02:40 AM
