H3 power sunroof problems
Old 03-26-2011, 12:37 PM
biglol's Avatar
Default H3 power sunroof problems
Anyone help .. I have an h3 2006 model ... All of a sudden the sunroof wont work.. Switch is clicking but no movement. Does anyone now if there is a resett for the sunroof anywhere ??
Any help please .. Cheers ian england ...
Old 03-26-2011, 12:41 PM
drtom's Avatar
Banned
fuse?
Old 03-26-2011, 12:43 PM
biglol's Avatar
Default Fuse ...
Check fuse fella .. All ok .. As i said the power is getting there but no movement at all ... Cheers ian
Old 03-26-2011, 03:54 PM
08JJ's Avatar
I had never really thought about this one but is there a way to manually move it back into place? Years ago you could manually crank if the motor dies....that would really suck if you were wheeling and a big rain cloud appeared...hmmm...would like to see if anyone had a fix for this other than garbage bags and duct tape.
Old 03-26-2011, 06:01 PM
drtom's Avatar
Banned
both fuses.
f9...10 amp....control
f57..30 amp ...motor
relay 88
Old 03-26-2011, 08:18 PM
biglol's Avatar
Default Replace fuses ...
Yes i checked the 30amp ... But not the others good idea .. I didnt know about the others manyy:d thanks i will check the rest in the morning thanks again .. I will let you know about my progress .. Thanks for your help .. Cheers ian ..
Old 03-27-2011, 11:58 AM
biglol's Avatar
Default Power sunroof ...
YES ALL FUSES AND RELAYS ARE ALL OK .. AS I SAID THERE IS A CLICKING COMING FROM THE SWITCH INSIDE THE CAR,, SO THERE IS POWER GETTING THERE OK.. ?? STRANGE .. IS THERE A SWITCH INSIDE THE CAR THAT MIGHT OF TRIPPED OUT MAYBE ??.. OPEN TO IDEAS.. THANKS IAN UK ..
Old 04-14-2011, 09:34 AM
biglol's Avatar
Sun roof fixed.. Sometime in the past the dredded water leak has got into the roof motor and seized it .. Some oil and a little time .. Problem fixed.. Thanks for all your help. I hope this helps others .. Cheers ian uk ...
Old 11-02-2015, 09:25 PM
joeyb's Avatar
Would like to know if you got the sunroof fixed, because mine is doing the same thing except it moves just a little and then starts (click,click,click)
Old 11-03-2015, 12:27 PM
You think he/she is still here 4.5 YEARS later????
Take a look here: https://www.hummerforums.com/forum/n...bumping-23220/
Quick Reply: H3 power sunroof problems
