Transmission speed sensor
Old Feb 27, 2019 | 05:48 PM
Davidburke's Avatar
Default Transmission speed sensor
I am having a problem with my 2009 H3T sometime when I come to a stop my speedo stops working and it wont shift out of low, well after some resea
rch I figured it out but now I cant find the trans speed sensor location can anyone help?3.7cylinder auto
Old Feb 27, 2019 | 06:52 PM
Davidburke's Avatar
Default Output Speed sensor Location
Correction on the thread before sorry!!
Old Mar 1, 2019 | 12:41 PM
Speed sensor is not in the Transmission, it is in the T Case, back side near the top. If it is not screwed in all the way, or has a bad connection, you will have the problems you describe.
Old Mar 2, 2019 | 09:39 AM
Davidburke's Avatar
Thank You Sir, the sensor was tight so I took the wire out and cleaned it and put connection grease on it so I hope that takes care of it. Thanks Again!!
Old Sep 28, 2024 | 10:05 PM
Hummync's Avatar
input transmission speed sensor is inside transmisdion , and causing bad shifting.
output sensor is outdide transfer case. Both of them us not very difficult to replace, remember disconnect negative from battery
Old Sep 30, 2024 | 09:31 AM
Nice job of tacking on to an Old Azzed Thread from FIVE YEARS AGO. NOT! READ: Old Threads/'Necro-Bumping'
jman1335
Jan 26, 2021 06:15 PM
Jbrashers
Feb 19, 2019 09:45 AM
mtauseefsa
Jun 19, 2012 09:05 AM
bheff
Jun 24, 2011 08:41 PM
bheff
Jun 15, 2011 06:35 PM
