Replace front lower control arm bushings?
Old Jun 25, 2023 | 01:17 PM
H3T Stick's Avatar
Default Replace front lower control arm bushings?
Ok, I have the front end disassembled. New upper control arms are installed.
Front shocks are out and the Bilsteins are waiting to be installed.
CV's have new boots and grease. New diff seals are installed
Front Differential bushing is out, and waiting to install the new one. The old one wasn't too bad, but it did have some cracks and needed to be replaced
The torsion bar is out on the drivers side (still fighting the passenger side).
Lower Ball joint on drivers side had started to wear.
New lower ball joints are installed on drivers side (passenger side is out, waiting to install new one).
Question:
Should I go ahead and replace the lower control arm bushing that go to the frame?
Looks like I have to take the front axle out (or least move it out of the way).
I guess I use the ball joint tool to remove the bushings that are on the truck.
Any suggestions?
For reference, the Hummer as about 85K miles on the clock.
TIA
Old Jun 25, 2023 | 07:19 PM
My '07 Uppers & lowers are OEM untouched virgins. When the day comes the CA's show wear on any point. I'm not going to mess with 17+yr old CA's. I will just remove, throw to the curb, and replace. 2023 control arms are cheap, look here>>>>2006-2010 Hummer H3+T Control Arm - Front, Driver and Passenger Side, Lower
Old Jun 26, 2023 | 12:41 AM
H3T Stick's Avatar
@hummerz Thanks for the information. I should have been more specific.
The bushing in question is the one on the frame.
Did find one post where someone had replaced the frame bushings.
Was wondering if anyone else has done the frame bushing replacement and if they had any words of wisdom.
Old Jun 26, 2023 | 03:24 PM
Happy Hummer's Avatar
Pictures plz? I'm uncertain what you are referring to.
Maybe this???
Old Jun 26, 2023 | 08:03 PM
H3T Stick's Avatar
@Happy Hummer As requested, here is a picture of the frame bushing in question
Frame Bushing on the Driver's Side
Old Jul 4, 2023 | 08:41 PM
H3T Stick's Avatar
Here's a quick write up. Hope that it helps someone down the road.
Old Jul 5, 2023 | 02:51 PM
Thanks for taking the time for a write up!
Old Jul 5, 2023 | 04:00 PM
Yes, thank you for the write up.
Old Dec 1, 2023 | 05:23 PM
teahead's Avatar
Maybe this???
https://www.youtube.com/watch?v=FFME7-fAFso
Can't you just buy these?
https://www.ebay.com/itm/26608492971...hoC8UUQAvD_BwE
Old Dec 2, 2023 | 12:08 PM
Justinh's Avatar
There's some confusion. The OP seems to be only concerned about the control arms, then he says "Front Differential bushing is out ...", so I think that is why Happy was asking about the axle bushings. The OP clarified that he was not concerned with the axle bushing.
Regarding the bushings Happy referred to, yes, the ebay bushing kit seems to be the same thing.
ACCLR8N
Dec 9, 2023 09:02 AM
H2-SUT
Jul 3, 2021 12:20 PM
Daniel Z
Jan 16, 2021 08:37 AM
H2Miami
Mar 19, 2017 01:09 PM
