-   Hummer H3T (https://www.hummerforums.com/forum/hummer-h3t-39/)
-   -   Help! No fuel pumps anywhere?? (https://www.hummerforums.com/forum/hummer-h3t-39/help-no-fuel-pumps-anywhere-48664/)
Backporch73 Dec 24, 2024 12:02 PM
I need help. I cannot find a fuel pump replacement any place that fits my truck. The Bosch was completely wrong. GM discontinued production of fuel pump for the 2009 Hummer H3T Alpha last year. The only aftermarket I could find was Bosch and that was wrong and they said that is the correct part number so they had to remove that from their catalog.
does anyone know of any fuel pumps available for a 2009 H3T Alpha?
bronxteck Dec 24, 2024 02:47 PM
you might have to reuse your pump housing and just replace the actual pump with something similar.
Backporch73 Dec 24, 2024 03:46 PM
so just cannibalize like a universal fuel pump and replace the components? I guess that’s my only option. There’s nothing left no backstock in the aftermarket groups. Haven’t started making them yet. Just had a bad window. Thanks for your reply bro
hummerz Dec 24, 2024 07:00 PM
What's "completely wrong" with the bosch 67791?:confused:
2009 H3T fpm part numbers listed below:
MU1883, M10229, 67791, 69446, 19207847, 19207848 19208880, 19208881, 19370390, 19370392
Here's a fpm on da'Bay with free shipping 30day return(seller would most likely just issue a refund if it doesn't fit)
>>>>Fuel Pump Assembly for 2009 Hummer H3 & H3T 3.7L 5.3L GAM1310
hummerz Dec 24, 2024 07:14 PM
https://cimg4.ibsrv.net/gimg/www.hum...943210b895.jpg
https://cimg4.ibsrv.net/gimg/www.hum...4941f206ec.jpg
hummerz Dec 24, 2024 07:17 PM
https://cimg7.ibsrv.net/gimg/www.hum...09cddfd940.jpg
bmcgarvey10 Dec 25, 2024 11:56 AM
Hummerz,
Thanks for posting those. What’s your opinion: I have no issues with mine but would you suggest buying one just in case if stock is tough to find?
Doc Olds Dec 26, 2024 12:18 PM
Hey BP73, what's up?
Can you expand upon why the Bosch pump you bought was wrong? RockAuto has the Bosch pump for the H3T Alpha as well so I am wondering. RockAuto shows the MU1883 for the H3 Alpha and they have them in stock. I do not know if or what the difference would be in fuel pumps for the H3 Alpha vs H3T Alpha.
Is it possible the pump you got was in the wrong box?
Best of luck.
hummerz Dec 26, 2024 12:57 PM
Originally Posted by bmcgarvey10 (Post 412717)
Hummerz,
I wouldn't stock electronic parts without testing. If you decide to get 1 install it within the warranty/free return window to make sure it works properly and keep the old for backup.
Backporch73 Dec 27, 2024 12:26 AM
Best of luck.
OK, thanks I’ll check this out. I’m pretty sure the pub that they sent me was for the five cylinder not the VA, which is why it wasn’t the same at all. However, it was listed as the V8, but it wasn’t. I’ll try those part numbers you’re talking about.
https://cimg4.ibsrv.net/gimg/www.hum...59922550a4.png
