Battery draining
Old 01-17-2018, 01:46 PM
Tannerj's Avatar
Default Battery draining
Been having an issue with my 09 h3t's battery draining. Noticed the little light next to the CD player turns on even with the key off and CD player makes noise. Tried pulling the CD player to see if anything was stuck in it. Player was empty. Also will not load discs into it(6 disc radio)
Old 01-17-2018, 01:48 PM
Tannerj's Avatar
also it is only taking 12 hrs to drain the battery
Old 01-17-2018, 02:05 PM
Hiro's Avatar
Could be the alternator? My H2 started draining rapidly while I was on a road trip, tried replacing the 6 year old battery and that still didn’t work.Had to replace the alternator, then all was good!
Old 01-17-2018, 02:06 PM
Hiro's Avatar
Also, another post on this forum mentioned that it could be Onstar or other electrical components draining your battery even when the vehicle is off
Old 01-17-2018, 07:21 PM
Tannerj's Avatar
not the alternator... had it tested. Also recently replaced battery. I noticed the red light next to the CD player staying on at all times. I pulled fuse #13 (radio) problem has gone away seems to be related to that. Any other suggestions?
Old 01-17-2018, 07:23 PM
Tannerj's Avatar
How would I disconnect the instant. I don't use it.
Old 01-18-2018, 07:35 AM
Make sure all of the door pin switches are operational. Retained Accessory Power (RAP) will not shut the radio and accessories off if you have a faulty pin switch.
It is possible the ignition switch is not shutting down the accessory power.
That RED light is a security light on the radio.
Old 01-24-2018, 06:48 PM
Tannerj's Avatar
Update: found that the carriage on the CD player was messed up... bought new aftermarket head unit and wireing harness changed it out myself and problem has gone away.
Old 01-25-2018, 06:22 AM
Thanks for posting your fix! Glad it worked out for you.
Norseman
11-30-2017 05:56 PM
John Weaver
06-20-2013 01:18 PM
Champ53
07-19-2011 02:26 PM
syphon
01-02-2008 01:26 PM
brachilius
07-17-2006 11:28 PM
Quick Reply: Battery draining
