Affordable shocks for H3T
Old Feb 18, 2017 | 10:52 PM
seedorfj's Avatar
Default Affordable shocks for H3T
Hi guys, my girlfriend's dad has been convinced that her truck needs a new set of shocks and thinks it will probably cost 1000 dollars. After a quick search, I didn't see any shocks that cost more than 500. I figured if I could install a new set of shocks for a lower price I may be able to talk him into some that will give some increased performance. Are the shocks I have seen absolute crap off-brand stuff? Will I be able to install a new set of shocks with a floor jack and some everyday tools? When I search H3T shocks I get results with coil overs for the front, are these just to level out the ride and work in parallel with the torsion bars? Would it be possible or remotely beneficial to do a lower price conversion to coil overs on the front?
TL;DR
What are some good H3T shocks for some average crawling that may add a little flex and smooth out some higher speed rough road drives?
Old Feb 20, 2017 | 07:53 AM
All H3/H3Ts use shocks, not coil overs. That was a bad website. Shocks are a combination of budget and the ride you are looking for.
Monroe and KYB make some great replacement shocks with a decent price point.
I prefer the OEM Adventure shocks or ARB Old Man Emu Nitrocharger shocks (same ride as the OEM Adventure on road but better OffRoad then the OEM Adventure shocks.)
You don't even need a floor Jack to replace the shocks,just a sawsall. Cut off the top of the shock bolt sticking out of the frame mount for the front shocks (the bolt is usually rusted on), remove the lower nut/bolt and slide it out. Slide the new one in, compress the shock to get the lower portion to the a-arm. Rears have a lower bolt/but and 2 upper bolts per side. A little tricky to get to the first time but not super difficult.
Shocks are all a personal opinion of what ride you want, 4wheel parts has good prices and free shipping.
Old Feb 24, 2017 | 06:55 AM
Zero83's Avatar
Amazon Amazon
These are the ones i used.
EvanMEllison
May 21, 2013 07:28 AM
jbetz
Jul 29, 2011 11:16 AM
Zaytser
22
Oct 22, 2009 09:16 PM
