What is the average lifespan of the I-5 Alternator=before it fails?
Old Jan 13, 2020 | 11:01 AM
ski.dive's Avatar
Default What is the average lifespan of the I-5 Alternator=before it fails?
***I'm having issues with my Alternator
How long did yours last?
70k? 100k? miles
Old Jan 13, 2020 | 11:03 AM
How much wood could a woodchuck chuck, IF a woodchuck could chuck wood?
Old Jan 13, 2020 | 11:14 AM
ski.dive's Avatar
***I'm having issues with my alternator, I ask a question and I get
+Another SARCASTIC answer by TAINTER-
sar·cas·tic = marked by or given to using irony in order to mock or convey contempt.
Old Jan 13, 2020 | 12:57 PM
It's definitely the latter to make it absolutely clear.
Bad alternator = replace alternator.
To you, bad alternator = ask inept question about alternator life on an 10+ year old vehicle.
inept = generally awkward or clumsy; haplessly incompetent.
Old Jan 13, 2020 | 01:02 PM
ski.dive's Avatar
TAINTER=
With that attitude of yours=
You either need an Attitude Adjustment or..........
YOU REALLY NEED TO GO GET LAID!!!.
Old Jan 13, 2020 | 01:37 PM
Some are bad out of the new box, others could go 200,000 miles with no issue.....
Old Jan 13, 2020 | 01:55 PM
Many fail due to weak battery, another failure can be caused from jump starting another vehicle. My '07 alternator is still oem, however I've replaced my battery around every 3yrs, and I've never jump started another vehicle. It's important to check battery regularly.
Old Jan 13, 2020 | 02:10 PM
ski.dive's Avatar
My alternator starts off a 14.2V for the first 5 mins. of driving, then drops off to 12.9V?
Old Jan 13, 2020 | 02:19 PM
Try cleaning connections battery & alternator+check resting voltage on the battery (min 12.5+)
Old Jan 14, 2020 | 12:16 PM
CarlosC's Avatar
70k? 100k? miles
My original alternator lasted ~216,000 miles. I recently replaced it with the same OE unit and all is good again. Installation is a bit of a pain, but definitely doable if you're reasonably handy with tools. .
