weird running sound on cold start
Old Oct 23, 2024 | 12:36 PM
Catch cans are useless, and you might hear a change in vacuum sound, but not as you describe.
Old Oct 23, 2024 | 12:54 PM
NFS's Avatar
NFS
it might if it is letting in unmetered air into the intake that is not being registered to the maf sensor causing a lean fuel trim condition or random multiple misfire like a 300 code..
yes but I am not getting any codes and if it’s the catch can then why it only happen when the car on cold start not every single start
Old Oct 23, 2024 | 12:55 PM
NFS's Avatar
NFS
not like I described and surprisingly the catch can caught some oil before it dump it to my intake I like it it keeps my intake clean
maybe I’ll see if I can like record a video and post it so you can hear the sound. I’ll do that after work today
Old Oct 23, 2024 | 01:50 PM
try retorquing your intake manifold bolts then. that can cause a hot / cold issue. gaskets can shrink in the cold
Old Oct 24, 2024 | 06:40 PM
NFS's Avatar
NFS
Here is a video I uploaded
see how you hear like dee dee dee Dee for few seconds then it go back to normal
Old Oct 24, 2024 | 07:01 PM
I can hear a worn pulley bearing.
Old Oct 24, 2024 | 07:59 PM
NFS's Avatar
NFS
really? Pulley bearing? Like the idler pulley?
you didn’t hear back from the exhaust or front where it like does dee dee Dee I swear I can hear it it’s not normal . Maybe I will take another video to see if I can get a clearer sound
if you listen like after 15 secs in you will hear it
Old Nov 5, 2024 | 12:39 PM
NFS's Avatar
NFS
Here is another video that’s clearer
if you folks can hear it and help me out would be great
Old Nov 6, 2024 | 01:47 PM
Happy Hummer's Avatar
Yes, there is an uneven running sound. Check compression, relative compression and clean your maf. Just a thought as a starting point. Clean TB. Tighten intake manifold bolts.
Old Nov 6, 2024 | 01:56 PM
NFS's Avatar
NFS
yes it only happen when the engine is cold like first start. If I go somewhere and turn it off and back on it’s normal . It just first start when it’s fully cold it does that for like 10 secs 20 secs then it goes back to normal. I already cleaned the maf but I’ll clean it again and do the other tests and report back
