Using spare tire
Old Oct 21, 2025 | 11:23 AM
H3TB's Avatar
Default Using spare tire
Will running a new spare tire (Front Right) with three pretty worn tires harm the the drivetrain?
Old Oct 21, 2025 | 11:28 AM
H3TB's Avatar
Will running a new spare tire long term (Front Right) with three pretty worn tires harm the the drivetrain?
Old Oct 21, 2025 | 11:55 AM
Welcome.
Not so long as they are the same tire make, model and size. I say that because different tires from different manufacturers may be different actual size/diameter even though the tire size numbers are the same.
If the other three are bald, you should not drive on bald tires. Check them with a tread gauge for 4/32 minimum.
Old Oct 21, 2025 | 02:08 PM
Happy Hummer's Avatar
Talking
Come on Doc (lol) in my neck of the woods (just outside Chi town and Milwaukee) the peeps drive till the threads and wires are hanging out.... literally had a guy knock on my door to borrow tools so he could change a flat tire. I don't loan my tools to anyone, so went out with them and stood by while he swapped a tire down to the wire with a bald patched tire.
Old Oct 26, 2025 | 11:28 AM
BlueH3's Avatar
I have a similar question will the stock spare “work”on the H3 when the other tires are upgraded from the 265 to 285’s thus slightly smaller - probably not right?
Old Oct 27, 2025 | 11:54 AM
NOT is correct. When you carry a smaller tire on the back, you are just hauling it around because using it for a spare with cause issues in the Diffs and T Case.
Bullwheel
28
May 12, 2011 03:28 PM
palmid
Dec 29, 2010 10:08 PM
rizaski
Sep 1, 2010 06:58 AM
vinny
Jun 4, 2010 06:10 AM
StarsnBars
Apr 20, 2007 10:59 AM
