U-Joint/Drive Shaft issue? Not moving when turning.
Old Aug 14, 2016 | 03:13 PM
user 956363738's Avatar
Banned
Default U-Joint/Drive Shaft issue? Not moving when turning.
Last week I got my drive shaft replaced (2 rear u joints connecting them are new), the mechanic forgot to put on a new front u joint so I noticed a vibration at high speeds while taking my foot off the gas (Chevy dealer said it was a bad front u joint). Was going to take the H3 back to the mechanic to install a new u joint in the front. Today while backing up I noticed a loud grinding noise when in motion (low speed) and when I turned the wheels, to the left or right, going forward or backward, my H3 came to a stop while my foot was on the gas.
Could this be due to the bad front u joint or the new drive shaft possibly being installed incorrectly?
Having it towed to the GM dealer in the morning, but hopefully looking for answers before then.
Thanks guys.
Old Aug 14, 2016 | 04:20 PM
happythree's Avatar
left button, 4hi,,,NOT 4LOCK
Old Aug 14, 2016 | 04:37 PM
Banned
Thanks happythree, but its been in 4hi (not lock) the whole time.
Old Aug 15, 2016 | 07:11 AM
Most of the time a u joint will explode dropping the drive shaft to the ground. Was the shaft stuck in the road and stopped forward progress?
Old Aug 16, 2016 | 12:49 PM
Banned
Just heard back from the mechanic at the Chevy dealer. There are a few problems. First, the front u joint is wobbling, so that needs to be replaced. Next the guy said that the transfer case has a leak and the transfer case control module and motor encoder need to be replaced.
They want around $1,500 for parts, labor, and disposal to do the repairs. Cleary that is outrageous, so I will purchase the parts (need to find the part numbers) and find a mechanic to install.
Old Aug 16, 2016 | 01:47 PM
HUMTECH's Avatar
I would get a second opinion, pretty rare that you would need both the encoder motor and the shift module. H3's had a common issue with sticking buttons on the selector switch in dash. Ask him what trouble codes lead him to the module and encoder motor.
Old Aug 16, 2016 | 01:49 PM
HUMTECH's Avatar
BTW ive been working on these since they arrived at the dealer. When we were a Hummer dealer I was the tech who did all the work on them
Old Aug 16, 2016 | 07:46 PM
happythree's Avatar
so, i wonder why it didnt move??
Old Aug 16, 2016 | 07:53 PM
Banned
I'm taking it a different place tomorrow. I have no trust in that dealer who also said I needed to replace the spark plugs for $500+, not knowing that I did it less than a month ago.
But I will have the front u joint installed, since more than one place said it was bad and wobbling. I will also do the transfer case motor encoder. Should be pretty simple to do myself. If the problem isn't fixed after than then I will do the transfer case control module, which also seems simple to do. Hopefully this fixes the issue of the car coming to a complete stop when turning the wheels all the way.
Old Aug 16, 2016 | 10:59 PM
happythree's Avatar
did anyone think of shift fork on this 06 h3?
