Turn off TPMS light after new wheels?
Old Sep 28, 2021 | 08:53 PM
mikesbaron's Avatar
Default Turn off TPMS light after new wheels?
2007 H3
Is there a way to permanently turn off or disable TPMS warning lights on dash after putting on new aftermarket wheels with TPMS's?
Old Sep 29, 2021 | 12:42 PM
No............. because if the TPMS are ACDelco OEM replacements they work and doesn't matter what wheel they are in.
Old Sep 29, 2021 | 12:43 PM
mikesbaron's Avatar
I'm not wanting to swap them out to the new wheels. New wheels are on without sensors, OEM wheels with sensors are no longer going to be used-ever.
Old Sep 29, 2021 | 01:21 PM
Kinda silly to put on a set of wheels and skip the TPMS when you know your vehicle has Tire Pressure Monitoring System, then decide after you do not like the tire light on your dash?
Old Sep 29, 2021 | 01:40 PM
mikesbaron's Avatar
Do you have anything productive to contribute to the original post?
Old Sep 30, 2021 | 09:41 AM
Productive Contribution right here. How to turn off TPMS light on dash when using wheels without sensors.
Correct method.
1) Purchase a set of new ACDelco TPMS from rockauto.com H3 TPMS part # 20927604 or find them on ebay at a better price;
2) Take sensors and truck with new wheels on it w/o sensors installed to tire shop and have them install and program the new sensors.
Alternate: Start vehicle, press and release the trip odometer reset stem to turn off tire light every time you drive vehicle from now on.
Old Sep 30, 2021 | 12:23 PM
mikesbaron's Avatar
All info I already knew, and not the initial question.
Stop commenting on my threads unless it's answering my original post/question.
Old Sep 30, 2021 | 06:55 PM
Old Sep 30, 2021 | 11:15 PM
NMH3's Avatar
See the very first post, which was from Doc, and which answered your question. The answer was "No".
If your aftermarket wheels don't have TPMS sensors, you will get the warning every time. The only way to resolve that, as Doc explained, is to put sensors into the wheels and follow the relearn procedure to pair the new sensors to the BCM.
Old Oct 3, 2021 | 09:26 AM
Dylan Rogers's Avatar
Hey Mike, I haven't heard of anyone actually using one of these bypass modules, but they do exist: TPMS Bypass Module (eBay). If you end up trying it out, let us know if it works! I might eventually get around to figuring out a TPMS delete but for now I am dealing with other stuff haha. Best wishes!
