Tracción control fail stability control sistem fail and 4WD service
Old Dec 27, 2018 | 12:08 AM
Gus Rios's Avatar
Default Tracción control fail stability control sistem fail and 4WD service
My 2006 h3
I bought my H3 2 months ago after I drove less than 100 miles after I purchased bringing home
abs and stability control warning lights came on
and the screen shows
fail stability sistem
service 4WD
abs
tracción control sistem
fuel cap ( already replaced) still showing in the screen once in a while
someone has the same issue??
thanks
Old Dec 27, 2018 | 08:40 AM
Welcome to HF. Easy stuff first.
I would start with looking at all the connectors and wiring to the ABS wheel sensors to make sure they are all correctly/completely snapped together and there is no fraying or cracks in the insulation. You could also disconnect each snap together connector and spray them with electrical contact cleaner, let dry, and snap back together.
For fail stability system, service 4WD a common cause is the Transfer Case Actuator motor, so first check the wiring and connectors to that.
Wipe the fuel cap gasket and fuel filler lip clean with a mild cleaner like ArmorAll cleaner or just plain old soap & water. Dirt, crud, corrosion on the fuel filler gasket surface can cause a small leak.
If after that you find nothing, then let us know.
Old Dec 27, 2018 | 09:59 AM
Gus Rios's Avatar
Default 4WD transfercase
Hi
thank you for the advice
already replaced the transfercase actuator motor
the warning lights still on also the 4x4 buttons on dash doesn’t work properly any button lights up now.
I don’t really know what to do.
thanks.
If after that you find nothing, then let us know.[/QUOTE]
Gord C
Dec 1, 2018 09:34 PM
byeatts
Sep 17, 2017 04:08 PM
6spd04cobra
Jun 3, 2011 03:08 AM
TerrySW
Apr 29, 2010 09:59 AM
Sundrop Addict
16
Mar 2, 2010 08:41 AM
