Towing Capacity H3
Old Jan 25, 2015 | 03:32 PM
hifiguy's Avatar
Default Towing Capacity H3
Hi All,
Actively looking for a 2007-2010 H3 (non Alpha) for work (towing about a 2k trailer) and PLAY (towing a 3.4k boat). I just need to know if it can do the job before pulling the trigger.
(btw, boat: 2004 Monterey 200LS 5.0)
According to specs, the boat is about 3400 pounds dry (not sure with or w/o the trailer). So I'm thinking that with a full tank, 4 adults, I might be shooting beyond the stated capacity of the H3 (4500 pounds).
We don't go anywhere but Saguaro or Canyon lakes - less than an hour away with only a few small hills.
Will the H3 be adequate for this kind of weight/stress?
Suggestions?
Old Jan 25, 2015 | 03:51 PM
hum4me's Avatar
I have hauled more myself it does the job but would not recommend it usually you can get away with a ton over but this would negate any warranties. believe the manufactore always underrate their equiptment a bit knowing people like myself are going to push it to the limit & then some. I usually stay 1 ton or under over the limit anything after that I pull out the big guns F350
Old Jan 25, 2015 | 04:39 PM
hifiguy's Avatar
So.. I understand it's not going to pull 4500lbs at 65 up a mountain. But what have you experienced when towing?
Currently, I tow the boat with a 2003 Astro:
4.3/190hp @ 4400 rpm
250torque@2800rpm
3:42 gears
As I understand, the H3 (2007 and newer) is this:
The H3 sports:
242hp @5600rpm
242tq @4600rpm
4:56 gears
Old Jan 25, 2015 | 05:31 PM
hum4me's Avatar
250torque@2800rpm
3:42 gears
The H3 sports:
242hp @5600rpm
242tq @4600rpm
4:56 gears
Alphas w/4:10 ,sport w/4:56 gears
Old Jan 25, 2015 | 07:51 PM
GunShow69's Avatar
Originally Posted by hum4me
there are some w/4:10 the highest is 4:56 gears
4:10 is in the Alphas
Old Jan 25, 2015 | 08:16 PM
hum4me's Avatar
2008 Alpha 6000 towing capacity that would take care of hifiguy needs but it seems he's not interested in the that one
Old Jan 26, 2015 | 03:31 AM
choochmalooch's Avatar
Cool
You should be good. The trailer is about another 800-1000lbs and you only want to go a short distance. The H3 is rated at 4500 but I'm sure you can tow a good 5000lbs, just not easily or economically.
Old Jan 26, 2015 | 08:40 AM
hifiguy's Avatar
Thanks Chooch',
I'll certainly be babying it being at/beyond capacity. My main concern is that I haven't done this with an H3 and not quite sure what to expect. Drove an '08 Tahoe LTZ in a past life and had no problem using OD.
With the torque of the H3 such that I can still do 50mph on a 1/2 mile 7-10% grade without putting my foot thru the floorboard? (Yes, definitely using lower gears etc.)
Really like to hear from a redneck that didn't blow his rig trying this..
Old Jan 26, 2015 | 10:48 AM
2007 H3 with Performance (Air Doc Intake, PP TB, PCMofNC.com tune and Efan conversion, MagnaFlow Cat Back exhaust) and Off Road mods (weighs almost 6000# with me in it) on 305 MTZs. The boat, Chaparral 2330 7.4L Big Block with Bravo 3 dive and tandem axle trailer appx. 5,500#, hauled from south of Milwaukee back to NE of Detroit (appx 425 miles one way).
Tucked in behind a semi, 70MPH all the way (65 hp the big hills and 75 down the other side). Beating feet heading out of West MI as the sun sets.
Would not recommend that, do not want to do it again, but the truck did everything I asked of it and got the job done.
Your boat is lighter, and your distances shorter. I brought that boat home solo with some tools and a floor jack. Load your truck up with 3 people and all your stuff, you will be overloaded too.
Old Jan 26, 2015 | 11:12 AM
I think everyone missed that he will also be towing a 2000lb trailer for work too. If that's everyday wear and tear on the poor I5, driveline and brakes will rear its ugly head much quicker than just towing a heavy load one in while.
