TIRE SIZE 315 or size smaller ?
Old Jan 6, 2013 | 09:27 AM
  #21
Drewski's Avatar
I like the look of those 315's, I still ride the stock 285's myself
Old Jan 7, 2013 | 05:38 AM
  #22
justanotherhemi's Avatar
I went from the stock 285 duelers to 315 Nitto TrailGrapplers. As far as the size upgrade you will definitely notice the drop in power resulting in a loss in mpg. I went from 19mpg to 15.5mpg average with the tire upgrade. I recently had my pcm tuned by a local shop FPT and the truck has come back to life. My mpg are up to 18.5 and the truck feels much lighter with better throttle response. As far as the tire is consered the 285 duelers were good and offered no rubbing or hitting in stock form. The 315s due rub just a little bit on the stabilizer bar but only when wheel is turn completely. I have had mine on for a couple of months and have only rubbed a few times. A far as the Nitto TrailGrappler is concerned it is a great tire. It is a mud tire with an all terrain tire in one. The noise increase between the duellers and the TrailGraps was minimal. In cab noise is at a very comfortable and tolerable rate that doesnt disturb any of my passangers. Good luck on your search
Old Jan 7, 2013 | 07:23 AM
  #23
Hummer79's Avatar
Thanks that helped alot I'm gonna go a 315 ordering them today and I was wondering about the PCM tune how much was it and what type of place did u have do it
Old Jan 7, 2013 | 09:41 AM
  #24
telemike's Avatar
I had PCMforless.com do mine for $199
Old Jan 7, 2013 | 09:46 AM
  #25
Hummer79's Avatar
Did you do the send in PCM and they send it back to you also how fast did you get it back also what did u know to tell them for the PCM for them to flash
Old Jan 7, 2013 | 10:28 AM
  #26
Hunner's Avatar
Originally Posted by DAGKANA
315: heaviest of the three options, however an additional 2" of ground clearance (in theory) over the 305s so for wheeling the best option ground clearance wise for obstacles.
I gotta mess with you on that Democratic fuzzy math theory. What two tires did you compare???
Is there that much less height in a 305? 1 1/4?
With the two I used it was more like 3/4 inch with a 285 and 315 dividing the circumference by two.
Old Jan 7, 2013 | 11:21 AM
  #27
telemike's Avatar
I drove to PCM's NC shop since they were only 80 miles from me. if you look at thier website, they have options for mail order.
I wanted to go 315, but since I will only be going off-road a few times a year I could notjustify the cost of 5 tires and the decreased mpg's for daily driving.
Old Jan 7, 2013 | 11:28 PM
  #28
Hummer79's Avatar
I have held off I'm still making my mind up I really don't want to go into fixing rear ends and trannys and the little motor turning the big tires I have went through that before on my last truck and it was awful the 315 is a big heavier tire but this hummer is my dd and I really like it and I plan on getting more hummers because I love this one so much and I want it to last my h3 has 107k miles on it now and I don't really want to tear anything up but then again I want to offroad with it because that's what it was built for so I'm leaning toward a 305 tire any opinions
lisastewart
Apr 10, 2009 06:06 AM
RealJeep
May 27, 2008 07:40 PM
Lane
23
Jun 13, 2007 03:11 PM
Greenblade
Feb 22, 2007 07:34 PM
dilo2001gt
16
Oct 26, 2006 01:34 AM
