Steering Wheel Vibration at Idle
Old Mar 27, 2026 | 01:38 PM
thebigbluesy's Avatar
Default Steering Wheel Vibration at Idle
I just had the upper and lower steering shaft and engine mounts replaced and now the steering wheel is vibrating worse than it was before. Not really noticeable while driving, but you can see and hear what it?s doing while at an idle. Park, Reverse, and Drive are about the same and the vibration is maybe half as bad when in Neutral.
Ideas? Suggestions?
Thanks,
Eric
File Type: mov
Old Mar 28, 2026 | 10:41 PM
Spanovich008's Avatar
Check that your front differential bushing bolt is not rubbing up against the engine oil pan; if it is, it will make an atrocious vibration that can be felt throughout the car and will vary with intensity depending on how fast you’re going and which way you’re turning.
humbum01
Hummer H3T
Jan 27, 2022 08:05 AM
Chimpy
Feb 23, 2018 04:59 PM
FLblueH3
Apr 9, 2015 12:16 PM
xtremez28
Dec 15, 2014 03:13 PM
markiemark
Apr 15, 2010 12:13 PM
