Starting Problem
Old Apr 13, 2023 | 01:45 AM
jackseel's Avatar
Default Starting Problem
Hi Friends,
I have Hummmer H3 2006. I am having a strating problem with my Hummer. When i starting in the morning there is no problem.
But, when i go shopping and try to start after one hour, there is crank and will not start and keep try to start it will strat after 5/6 time. I have already change my Starter Motor and Battery. Also checked alternator.
It would be appreciated in anyone expreience the same, can help me to find the reasons / solution for this strating problem.
Thanks.
Old Apr 13, 2023 | 03:10 AM
Disel's Avatar
is there an error indication? Does the lock blink red on the dash?
Old Apr 13, 2023 | 03:30 AM
jackseel's Avatar
Yes. Red Battery Light.
Old Apr 13, 2023 | 03:49 AM
Disel's Avatar
if only the red lock blinks on the panel and there are no other messages (checkin), then you need to reflash the brain. remove the default protection. the resistance in the ignition lock is not showing correctly. I disabled this feature. a lot of people had problems with it.
Old Apr 13, 2023 | 09:10 AM
Originally Posted by jackseel
Hi Friends,
Thanks.
Are you still trying to use the Crappy Azzed OEM Battery Terminal Connectors? If so, hack them off immediately and replace with a quality aftermarket set like Stingers or your favorite brand. #! first mod to do to any H3/H3T as the OEMs all fail, every one of them, known issue that causes many electrical Gremlins.
Then look into GM Passlock.............. search it out.
Old Apr 18, 2023 | 02:06 AM
jackseel's Avatar
Would it be due to "Crankshaft Position Sensor" problem?
Old Apr 18, 2023 | 03:45 AM
Disel's Avatar
Certainly. But you should then have an error on this issue.
I also recommend checking the fuel pressure. And fuel trim. If the nozzles are pouring heavily, then there will be the same symptoms.
chrisg75077@gmail.com
Nov 1, 2019 10:35 AM
greenb98
Jul 20, 2016 08:27 AM
buggzy
Mar 23, 2015 02:10 AM
HummerH3Texas
Jan 21, 2013 03:32 PM
OAHU_H3
22
Oct 18, 2012 02:23 PM
