starting to make it mine
RETURN THE LIFT KIT. YOU DO NOT NEED IT.
You can fit the following on a STOCK H3:
285/75R16
305/70R16
315/75R16
A 1/2" drive breaker bar and 27mm socket is all you need to turn the torsion bar bolts. Measure from center of the axle shaft to the wheel well. Do not exceed 24". 23.50" is max for safe CV shaft and steering angles. Stock should be 22.50". No adjustment to the rear needed. Adjust to desired height, drive around and work the suspension. Re-measure and adjust until it settles where you want it. Then get an alignment.
https://www.trailduty.com/product_in...0ee2f9d53aa9df
285/75R16
305/70R16
315/75R16
which should i order? the 1/2 or the 1. im not anywhere near my truck and i wont be for awhile. im just trying to get the parts together for when i get home
Mountain Trooper
Jun 3, 2007 06:56 PM
HummerGuy
28
Feb 22, 2007 01:40 PM
