Stability contol
Snowed up here in Mn last night (go figure, snow in Mn). Put the H3 in the road to clear the driveway. When done I got in and tried to drive up the road. Skid marks came on on the dash and I could feel brakes being applied. Took forever to get up the road turn around and come back home. Roads are slippery but I was babying it so wasn't slipping the tires. Figured I would turn off traction control and stability control. Dash said off but issue kept occurring. Did a search and could only find a very old thread but wasn't the same issue. Can anyone share with me what is causing this and can those nanny controls be permanently disabled. Any help would be appreciated. Only had it for a week and already love it, just looks like a few gremlins that need to be worked out. Thanks
Read the manual would be appropriate here.
Default TC and StabiliTrack is ON. Means if you turn it off, soon as you start the truck again, they will both be on. If you push the TC button you have to hold it for 5 seconds to turn OFF TC and StabiliTrack. If you just push the button and release, you turned OFF TC, but left StabiliTrack ON. I have looked into this further and you can take out almost all TC and StabiliTrack with a laptop tuner. If you try to take it all out, it will create some crazy issues, but if you take out say 91-94% and no more, it will allow you to get away with that. We were trying to get a 2009 Chevy Colorado LH8 Strip Truck to launch from the starting lights so I learned a bunch that day. It is set up so you really can never disable it, but you can temporarily turn it off with the dash button. |
Thank you, waiting for owner to send me manual, not sure why it wasn't in the glove box. I don't mean to ask stupid questions and do try the search function before asking but I am not sure I am putting in my search correctly. I have learned that if I get out of the forum and do a google search I seem to get better results. I do appreciate your patience.
What tires are on it and how worn are they?
Regular street tires, about half their tread left. Issue was I could not accelerate at all, brakes kept being applied even though I was barely doing 5-10 MPH. kept getting stabilitrak light and ABS fault. Rather weird but got back home and turned vehicle off and came in to try and find the answer to the problem. Went out and truck ran like it never had an issue, hasn't done it since. Tires are 265/65R18.
(Post 369538)
Default TC and StabiliTrack is ON. Means if you turn it off, soon as you start the truck again, they will both be on. If you push the TC button you have to hold it for 5 seconds to turn OFF TC and StabiliTrack. If you just push the button and release, you turned OFF TC, but left StabiliTrack ON. I have looked into this further and you can take out almost all TC and StabiliTrack with a laptop tuner. If you try to take it all out, it will create some crazy issues, but if you take out say 91-94% and no more, it will allow you to get away with that. We were trying to get a 2009 Chevy Colorado LH8 Strip Truck to launch from the starting lights so I learned a bunch that day. It is set up so you really can never disable it, but you can temporarily turn it off with the dash button. OK kiddies, that is your homework assignment: Find out what action is required to produce the "TRAC OFF" message, and what action to produce the "STAB SYS OFF" message, either together or separate. :D |
2008 H3 Alpha, (2) 2008 H3 Alpha Offroad, 2009 H3T Alpha Offroad, 2010 H3T Alpha Offroad & 2009 H3T Manual Offroad
in 4HI and 4HI LOCK: TC button you have to hold it for 5 seconds to turn OFF TC and StabiliTrack on all of them in 4LOW LOCK: the vehicle does it by itself |
