Squeak, Rattle, Clunk, Etc...
#22
RE: Squeak, Rattle, Clunk, Etc...
my h3 07 22,000 miles is quiet as a whisper on pavement but as soon as i leave it and go on more dusty rocky roads, and in my case every day, it sounds like a bloody concert hall especiallya this one damn noise that seems to come from the right rear wheel when i hit a pothole!!
as someone says it adds to the rough looks i love my noisesthey just remind me that i m not on a boring interstate
#23
Hi...first time post...long time lurker....
I have the same thing...it's an 06...and another 06 our company owned had the exact same squeak from the rear. Only thing I can say is that when I whacked the spare tire I did sort of re-create it. Just need the time to dig into it...hopefully it's something like the jack.
#24
alrock, I had a problem like you describe on my old Discovery. I found about a 3 inch curb and hit it until the noise was steadily repeating then tried different things until I got it to stop. It went away when I would put slight pressure on the brakes so the pads would stop shifting in the caliper.
#25
I had alot of squeeking noise also and I was able to find out the problem, the problem was that onthe left said there is the parking break and the connection comes lose and it also causes the brace to come lose which makes the squeek. I had to have it fixed twice already and it is totally annoying.
#30
what I do is go over most nuts and bolts and snug them down. A 2008 is now 3 years old and theses items do tend to loosen up. The factory torques everything down, but they do work loose. On my side steps, the drivers side was creaking every time I stepped on it, on checking the bolts, I found that one of them was cross threaded and was only threaded in about 5 threads leaving 3/4 of the bolt sticking out. Once snugged down, creak was gone, and this was from the factory.
I also open the fuse and relay boxes and push all the fuses and relays to make sure they are snug-get rid of the electrical gremlins. Why cause these are also inserted by factory robots........
