Service Tire Presure Monitorng (TPM) Sys
Old Oct 19, 2019 | 01:00 PM
ReRun0007's Avatar
Default Service Tire Presure Monitorng (TPM) Sys
msg directly above odometer says "Serv TPM Sys"
additionally the tire low pressure indicator remains illuminated
Mechanic says "it's a computer issue and expensive to repair"
What R ur comments? My tires are properly inflated
Richard Ingram rdi0007@yahoo.com
reply via e mail pls
Old Oct 19, 2019 | 02:03 PM
You want an answer check back to this forum.
Raise air pressures to 38psi then drive it and advise the outcome.
Old Oct 20, 2019 | 06:35 AM
wpage's Avatar
Agree, sometimes on my h3 when we get cold nights a false alert comes from TPM due to atmospheric contraction in the tire from cold. Go air up. That usually clears my alarm.
Old Oct 20, 2019 | 07:48 AM
Mambachee's Avatar
Default My Fix
I had a bad tire sensor. But the tire show couldn’t get it to reset. Did a little research and found it had to be driven. 38 pounds all around. Going down the road push the trip button once, all lights and warning gone.
Old Oct 20, 2019 | 10:39 AM
Ordieh's Avatar
Where does the 38 PSI recommendation come from. The door sticker on my ALPHA X says 32 and that is what I have run for years with no problems. The door sticker on my CE says 35 which I have run for years and no problems. Did GM have a tech update that I missed?
Thanks in advance!
Old Oct 20, 2019 | 01:59 PM
wpage's Avatar
Thanks in advance!
Its a way to clear a false code...
Old Oct 20, 2019 | 02:51 PM
Thanks in advance!
Northern cold climates. Just enjoy that 89°F that you currently have there. It was 35°F
this morning here. Btw, my door placard shows 35psi for the front/rear tires and 50psi for the spare.
Never got a warning light even with sub-zero days, since running my tires @38psi.
Old Oct 20, 2019 | 07:18 PM
Ordieh's Avatar
I spend a lot of time at almost 9000 elevation in Colorado in my CE(sometimes well below zero) and haven’t had a STM problem. I did replace all sensors with OEM when I put on my last set of tires. On here, I think I remember being advised to go only OEM. Maybe I have been lucky!
Thanks again
Old Oct 20, 2019 | 07:52 PM
Thanks again
It has nothing to do with being lucky! My '07 still has the oem tpm sensors and originally I would receive the warning light during cold temps. Correction was to increase the pressure. I check the pressures 1-2 times per year around 70°F ambient temp and pressures are still @38psi.
FYI, for every 10 degrees of temperature drop, tires will drop 1-2 pounds of pressure. It is important to keep your tires within the recommended PSI to maintain traction, handling and durability.
Old Oct 20, 2019 | 08:56 PM
WR3NCHE4D's Avatar
Just so everyone knows. The tire pressure settings can be changed in the BCM/TPMS module. I believe the default is set for "P" rated tires at 30psi and can be changed for "B" at 40psi, "C" at 50psi, "D" at 60psi and "E" at 80psi. If someone has changed the settings to a "B" rating, then the TPMS message will come on with the tires set at 30psi.
