Service 4WD alert. Concerning or no?
2008 H3. "Service 4wd" LCD alert comes on and stays on every time I start it up. My mechanic said it was the "transfer case shift motor." They replaced it and said that the "gears were shifting properly..." But, the alert is still there. They said it will go off eventually.. which is not something you ever want to hear your mechanic say. Truck is running great. But my OCD wants to make sure it is nothing serious. Anyone ever deal with this problem?
Never! Scan and post the codes.
Ignore...
1) Scan. 2) Unplug the T Case Actuator, clean the connection both sides w/ CRC Electronic Cleaner, re-connect. 3) Inspect the wiring harness to the T Case Actuator.
(Post 388689)
(Post 388720)
Originally Posted by wpage
(Post 388713)
Ignore...
(Post 388689)
Originally Posted by BlackDudeGreyHummer
(Post 388838)
Oh...! Might I also add that 1.) The buttons that allow switching between high and low do not seemingly work. They just flash for a while when I press them and then it returns to a solid light on the regular 4wd button. 2.) The vehicle is lifted pretty high. Not sure if that could be a factor. Seeing that maybe this affected the 4wd system?
(Post 388835)
Yeah? Care to expand?
So I ignore them. |
