Security light question
Old May 11, 2026 | 06:59 PM
Me 2's Avatar
Default Security light question
Does it matter if the security light is flashing or staying on solid to need a relearn?
Old May 26, 2026 | 02:59 PM
brothapig's Avatar
Are you referring to the padlock light on the dash? If it is flashing, your truck should not start. If it comes on steady when you are driving, itindicates a problem with the system.
If it is flashing when you start the truck, and it stays on after 5 seconds, something is not working correctly.
If it is flashing when you try to start the truck, and it does not start, wait 10 minutes and try again. If after three attempts it does not start it will need to be serviced.
Old May 26, 2026 | 03:02 PM
Me 2's Avatar
Thanks brothapig, I finally figured out it wasnt an issue to begin with. I got my BCM back from having the odometer reset and was told to do the relearn but security light was not flashing so finally started.
Old May 26, 2026 | 03:26 PM
Happy Hummer's Avatar
That's a good thing lol!
Waelhilal
Oct 16, 2019 07:05 AM
cprusik
Aug 31, 2011 07:52 PM
H3sweden
Mar 2, 2011 01:40 PM
hayabusa4448
Dec 28, 2010 08:53 AM
MTHUMMER29
Mar 28, 2010 10:21 AM
