Roof rack key
I'd be glad to make someone a copy of our key, but I cannot find any numbers on the roof rack. We have the original roof rack that it came with from the factory. Someone said it's right next to the key hole, but it's not. The number on our key is 138 if that helps any. Can someone tell me if that's the number or where I can find the number on the roof rack? Thanks
If you have a GM original roof rack then the number will be stamped right next to the key slot in the metal.
It will be SP1, SP2, SP3, SP4 or SP5
If you don't have one of those numbers stamped, then it is not a GM rack, or maybe the dealer installed an aftermarket rack.
Number on the key does not help. It's probably a key blank number.
Lots of aftermarket parts say HUMMER.
These racks were made by a third party for GM. Usually they were installed by the dealer.
GM charges an arm and a leg for their accessories. The dealer, or someone else, may have installed a clone to save money.
The clones would have been keyed differently from the ones made for GM.
Here's some aftermarket racks that you can get online today.
Notice they say HUMMER and they are "OE style"
06 10 Hummer H3 OE Style Roof Rack Cross Bars Set w Lock H3T Luggage 07 08 09 | eBay
http://www.ebay.com/itm/06-10-Hummer...item19d71a1383
http://www.ebay.com/itm/06-07-08-09-...item27c027766e
And just because it's aftermarket doesn't make it an inferior part.
In many cases, aftermarket is better than OEM.
