Reset Serv 4WD light
Old Sep 20, 2020 | 07:48 AM
H3Luxembourg's Avatar
Default Reset Serv 4WD light
Hello all, is there a way to rest the Serv 4WD light , after oil change in T-Case and Manual trans. oil?
Old Sep 20, 2020 | 04:37 PM
Scan and post the code.
Old Sep 21, 2020 | 04:46 AM
there is no code, only the message Serv 4WD
Old Sep 21, 2020 | 09:18 AM
RKSmith163's Avatar
There is no Maintenance Message for the Transfer Case and Manual Transmission. You have an issue somewhere else. Use the Search Function and will lead you to probable causes.
Old Sep 21, 2020 | 02:49 PM
I checked my BCM with my OBD2 reader and there are no error codes at all! There was only this message on dashboard, same like the oil change message but it was Service 4WD. I just pushed the oil reset and it's gone now......
Old Sep 21, 2020 | 05:04 PM
You need a scan tool that will read the tccm.
Old Sep 22, 2020 | 03:54 PM
have you cycled through your 4x4 settings? maybe encoder motor is a bit iffy.
Old Sep 22, 2020 | 06:30 PM
Always check wiring/connectors first.
Old Sep 26, 2020 | 04:10 PM
Changed oil in T case and manual transmission. The message is gone ....
Did the front and rear diff too, so the oils are all new at same time.
Old Sep 26, 2020 | 05:20 PM
Don't know how it works on your side of the pond? On this side, any warning light is stamped into the modules, failure time/date and code, retrieve that info and correct asap. Drive on and ignore like most do until a catastrophic failure.
