Remotes(FOBs) doing something interesting!!
After searching I needed to ask this....
I had my FOBs programmed a few months ago, everything going fine then they began to operate intermittently. Sometimes you could lock or unlock, sometimes not.
Now, nothing except if you place the FOB right next to the outside glass. What’s going on?
I’ve seen post that FOBs totally stop working, but not this.
Before anyone asked, I’ve replaced the batteries in the FOBs.
Any resolve to this matter?
The receiver is the BCM, and yes you could have a BCM that is going bad, or the connections for it may be loose, corroded, frayed, even the antenna (single black wire) can get loose. Pull off the passenger side kick panel and take a look.
