rear wiper
Old Nov 14, 2014 | 01:32 PM
ODIMUS's Avatar
still waiting for a day off to check for a clog in the line...
Old Nov 24, 2014 | 10:04 PM
alpine001's Avatar
Originally Posted by RKSmith163
Switch the hoses from each motor to see if they are working. They are easy to get to. They are located on the passenger side top of the firewall. If both are working, then you just have to start looking for an obstruction. The rear washer hose can be accessed by removing the jack cover on the tailgate. Good Luck
Is it possible to inadvertently switch the hoses backwards? If true then you just helped me figure out my problem. You see, when I press on the rear wiper **** center button, the FRONT wiper nozzles dispense fluid . I've only owned my beast a couple of months and today for the first time I tried to use the front wiper fluid nozzles. I'll switch the hoses and that should do it.
Old Feb 20, 2023 | 08:32 PM
waltham41's Avatar
I got lucky with mine. For some reason someone had pulled the fuse. I replaced the fuse and it's working fine.
Old Feb 21, 2023 | 01:24 PM
Boy that is lucky near NINE YEARS after this OLD Thread was started.
pduffy
May 3, 2008 05:51 AM
coreyc
Jan 14, 2008 10:00 PM
HummerGuy
May 31, 2007 07:47 PM
ZX10R
Mar 11, 2007 09:08 AM
bogy
30
Sep 23, 2006 04:04 PM
