Rear wheels look like they are further out
Old Feb 7, 2026 | 10:46 PM
Me 2's Avatar
Default Rear wheels look like they are further out
Finally got done replacing a ton of parts on this rust bucket and put the new wheels on, the rear wheels look like they stick out much further then the front! Is this an allusion or is this the way the h3/h3ts look?
Old Feb 8, 2026 | 07:39 AM
Justinh's Avatar
Did you measure? And what mode is your rust bucket?
Old Feb 8, 2026 | 09:12 AM
Me 2's Avatar
Not sure on where to measure from, it’s a 09 h3t
Old Feb 8, 2026 | 03:44 PM
What tire specs front & rear? Post some PICS!
Old Feb 8, 2026 | 03:50 PM
Me 2's Avatar
Rims are 16x8 -12 OS
Tires are 315/75
hard to really tell right now as I need an alignment badly after replacing everything underneath
Old Feb 8, 2026 | 05:22 PM
Tires are 315/75
The tires are 2" wider than OEM specs PLUS front alignment appears to be set at NEGATIVE CAMBER with the top of the tires leaning inwards. Get an alignment check ASAP!
Old Feb 9, 2026 | 12:12 PM
They do
Wheelbase 134.2 in.
Front track 65.0 in.
Rear track 65.5 in.
Old Feb 24, 2026 | 02:23 PM
linel's Avatar
Finally got done replacing a ton of parts on this rust bucket, including some BMW 1 Series parts, and put the new wheels on. The rear wheels appear to stick out much further than the front. Is this an allusion or is this the way the H3/H3Ts look?
That’s normal for the H3/H3T. Rear wheels are often wider or have a different offset than the front, which can cause them to appear to stick out more.
Old Feb 24, 2026 | 03:01 PM
NOPE!
Old Feb 28, 2026 | 09:08 AM
H3 wheels are all the same spec. If your ordered aftermarket wheels, then you could get different front vs rear wheels, but that would e a poor choice.
