Rear Washer Fluid Valve
Old May 15, 2024 | 08:01 AM
HumH3Buff's Avatar
Default Rear Washer Fluid Valve
Having an issue with my Rear Wiper/Washer. Found out that the one way valve that’s in the fluid line had deteriorated and clogged the feed. Took the valve out and straight lined the fluid but now finding out that there is an issue that once you finish supplying fluid that the system does not stay primed. From my research it looks as GM discontinued this valve.
Need your input for replacement or fix?
Old May 15, 2024 | 02:06 PM
a generic check valve should work fine as long as you install it with the correct flow direction. they used to have them in the help sections at autoparts.
Old May 15, 2024 | 02:22 PM
HumH3Buff's Avatar
Thanks!!
Should have thought of that on my own. Getting old sucks!
New06H3Used
Mar 21, 2020 03:20 PM
RickStang
Apr 19, 2014 04:30 AM
nlhummer
Mar 13, 2013 04:15 PM
uzz32soarer
Oct 30, 2009 08:15 AM
coreyc
Jan 14, 2008 10:00 PM
