Rear torsion bar "clips"
Old Jan 20, 2020 | 04:16 PM
brothapig's Avatar
Default Rear torsion bar "clips"
Hi all,
Was underneath my '07 looking at what I thought was a leak, but I noticed there are two round metal "clips" on the rear torsion bar, that are split and appear to have opened up. There also appears to be a pin that might go into the bar, at the spit. I am not sure what their function is, but I'm wondering if the condition mine are in is normal? I thought perhaps they were opening up for some reason. Mostly curious I guess.
Also, the leak I was chasing was dripping from what appeared to be the exhaust. Bright green like coolant. I caught one drip still on the exhaust pipe before the muffler, but it wasn't in a low spot like I would have thought it would be. My heart initially sank thinking it was coolant from my engine, but my engine has the orange dex-cool, and the level is full. I cannot think of anything else that would be bright green, so I'm convinced I ran over a mountain dew bottle!
The pictures show both the "leak" and the clip, but in the one picture you can see both the drip still on the exhaust, along with the other torsion bar "clip".
The evidence of the "leak"
More evidence further up the exhaust system
You can see the drip on the exhaust just before the muffler, but you can also see the yellow (brass?) "clip" on the torsion bar
Close-up of the "clip" on the torsion bar
Old Jan 20, 2020 | 04:53 PM
Rear sway bar (aka: stabilizer bar, anti roll bar). The rings are to limit lateral travel on the sway bar.
There should not be any leak on your pipe, unless there is a hole in it. The muffler has a drain hole in it, to drain the moisture.
Put a pan under/on those spots, start vehicle cold, let idle for for a few minutes, then check what's inside.
Old Jan 20, 2020 | 04:58 PM
the color of the fluid looks very close to AC leak detect fluid. are H3's equipped with rear AC?
Old Jan 20, 2020 | 05:40 PM
brothapig's Avatar
No rear ac on mine at least. I've been parking on snow and paying attention to it, and have not seen any more evidence. If I didn't see that one drop on the pipe I would have been convinced it didn't come from my truck.
Thanks for the info on the sway bar. I was curious as to what those were. I don't think any more will come from this "leak", but I'll post an update if I find out where it came from.
Thanks again!
Old Jan 20, 2020 | 06:07 PM
Thanks again!
It's always better to be sure. If you are forewarned, you have advance knowledge.
Old Jan 20, 2020 | 06:20 PM
Rear a/c? lol. The color looks more like sulfur.
Old Jan 20, 2020 | 08:13 PM
Bricks's Avatar
holy cow my sway bars don't have clips on em! If that's meant to limit the travel on the sway bars then that's prob why my trucks swaying out of control. Eureka! Thanks for the info
Old Jan 21, 2020 | 02:17 PM
Science lesson time. What happens to hot metal exhaust heat shields and pipes when sprayed with road salt?
First, there is nothing yellow to leak from an H3 unless you swapped out the Dexcool red stuff for Yellow antifreeze.
Answer: salt is sprayed on different metals (galvanized heat shield, mild to SS exhaust, steel clamps and hangers etc.... and the heat creates a chemical reaction to form yellow crystals (mostly zinc oxide) and those drip on the ground and snow leaving what appears to be a small yellow fluid leak/drip.
Old Jan 22, 2020 | 07:33 AM
Talking
Thanks DOC, just another reason to avoid the "yellow snow".
Datboy_B
May 31, 2014 10:51 PM
White Wolf
May 13, 2014 04:38 PM
Indy
Mar 7, 2011 08:33 AM
Kopfjaeger
Aug 9, 2010 10:22 PM
2zRescue
Dec 21, 2007 02:17 PM
