rear tires feathering on outside
Old Nov 22, 2025 | 01:16 PM
Justinh's Avatar
Default rear tires feathering on outside
I got new tires 3k miles ago. The outside edge tread band is feathering. This is unusual for a rear tire. What could be causing this?
Old Nov 22, 2025 | 08:38 PM
gaber6's Avatar
Have someone drive behind you and aee if you are crabwalking. Does it pull? Inflated to what the door indicates? Stock tires?
Old Nov 23, 2025 | 09:22 AM
Happy Hummer's Avatar
Causes of outer edge wear
Underinflation: This is a common cause, as low tire pressure makes the sidewalls flex more, causing the outer edges to carry the brunt of the weight during turns.
Negative camber: While not an adjustable setting on all solid axles, a negative camber angle (where the top of the wheel leans inward) will cause the outside edge of the tire to be in constant contact with the road. Worn out suspension components like springs or bushings can cause or worsen this.
Bent or misaligned axle: A solid axle can be bent from hitting a large pothole or curb, or it may have shifted from its original position. A shifted or bent axle will cause the wheels to sit at an angle, leading to uneven wear.
Aggressive driving: High-performance driving, especially with frequent, sharp turns, can accelerate wear on the outer edges of the tires.
Lack of tire rotation: If you don't rotate your tires, they will wear unevenly over time. This can exacerbate edge wear on a rear-wheel-drive vehicle where the rear tires do all the work
Just borrowed Google generated information. Could be more reasons.
Old Nov 23, 2025 | 08:45 PM
check your leaf spring shackles an bushings. could have a cracked leaf spring or shackle.
Old Nov 24, 2025 | 10:26 AM
What model/brand Tires and what PSI are you driving them with?
Old Nov 24, 2025 | 04:38 PM
Justinh's Avatar
Cooper Discoverer Road+Trail AT 265/75R16 @ 36-38 PSI. A visual inspection of the leaf spring hardware didn't reveal anything.
Old Nov 24, 2025 | 05:16 PM
GoGet a FREE alignment check & post a picture of the readings.
People also ask
Can you get your alignment checked for free?
AI Overview
Yes, many auto shops and tire retailers offer free wheel alignment checks, but a full alignment service is not free. Companies like Mr. Tire, Goodyear, BrakeCheck, Brakes Plus, and Discount Tire provide a complimentary inspection to determine if an adjustment is needed. If the check reveals a misalignment, you will be charged for the alignment service itself, which typically costs anywhere from about $50 to over $150 depending on the type of vehicle and service.
Free alignment checks
  • Many businesses offer a free check to assess the alignment of your vehicle.
  • This check often includes a visual inspection and a check of alignment angles.
  • You can get a free check at participating locations of companies like:
  • Mr. Tire
  • Goodyear
  • BrakeCheck
  • Brakes Plus
  • Pep Boys
  • Discount Tire
  • Big O Tires
  • Firestone Complete Auto Care (with tire purchase)
Old Nov 25, 2025 | 10:10 AM
Old Dec 1, 2025 | 04:13 PM
Justinh's Avatar
Could this be caused by the bad RHS front axle mount bushing? I'd guess it could make the truck sit a tad tad tad bit crooked.
bosch
Sep 25, 2016 05:39 AM
AR15wheeler
Jul 22, 2015 12:01 AM
ironbike1@q.com
May 16, 2012 06:46 AM
HawaiianH3
20
Jul 13, 2011 03:47 PM
No more Jeeps
Apr 4, 2010 08:42 PM
